Wheel alignment
PostPosted: Sun Sep 23, 2012 2:55 pm    Post subject: Wheel alignment Reply with quote
Can someone tell me the tracking on the series 6 Gazelle if its toed in or out or parallel so that when it goes for laser wheel alignment we know what it is because the garages wont know.
The Clan Chieftain
welshrover
PostPosted: Sun Sep 23, 2012 3:54 pm    Post subject: Reply with quote
toed in 1/8 of an inch. its the same as my wifes hillman minx series v Very Happy
PostPosted: Sun Sep 23, 2012 6:45 pm    Post subject: Reply with quote
Great...thanks very much Cool
The Clan Chieftain
welshrover
PostPosted: Sun Sep 23, 2012 11:02 pm    Post subject: Reply with quote
no problem Smile
Inglewood
PostPosted: Mon Sep 24, 2012 8:53 am    Post subject: Reply with quote
Up to date laser alignment equipment will measure far more than simple tracking:
Tracking - normally now measured in degrees & minutes
King Pin Inclination,
Caster,
Camber,
Toe-out on turns,
Rear tracking,
Thrust angle.
I good workshop should be able to obtain the measurement limits and tolerances.
Churchill Johnson
PostPosted: Mon Sep 24, 2012 9:28 pm    Post subject: Reply with quote
I could do most of those way back in 1970 with the up to date tools i had then in a garage without a laser in sight and up to that time i could adjust with shim's to rectify camber and castor and rear tracking misalignment [Vauxhall] but once the welded front axle beam's showed up that was it.
welshrover
PostPosted: Mon Sep 24, 2012 10:16 pm    Post subject: Reply with quote
laser alignment ! what are you having aligned, a modern car or a proper car, get yourself a gunson tracrite ive used one on all my classics cars for the last twenty odd years and never had a worn tyre yet through poor wheel alignment .ill tell you a story of how good laser tracking is, my mum has had two new tyres on a fiat punto a month ago which were balanced tracked by laser the two fronts are wearing on the inside allready. the cars only 2 years old so i cant see any wear bieng present and she doesnt drive above 50 any where ,so she took it back last friday it was a mile out toeing out .so well see how it fares this month. Rolling Eyes
Kelsham
PostPosted: Tue Sep 25, 2012 8:39 am    Post subject: Reply with quote
Take Welshrovers advice and buy a Trakrite, I too have owned one for many years and have found it invaluable.
On one car, I had the tracking done with laser equipment and still wore the tyres down on the edge.
I adjusted with the Trakrite and stopped the wear immediately.
Regards Kels.
