Joined: 23 Nov 2007 Posts: 4267 Location: South Cheshire
Posted: Sat Feb 23, 2013 6:47 pm Post subject: Initial static timing |
Want to fire the mga up for the first time it has an electronic distributor, any tips on an initial static timing?
I'm thinking of turning the engine over on the starter motor, no fuel without plugs in cylinders 2,3&4 and timing with a strobe?
Farmer John
Posted: Sat Feb 23, 2013 8:03 pm Post subject: Initial timing |
Hello Dave.
6-8 degrees static is fine for starting up. With electronic ignition there is a complication in deciding ( by looking in the distributor ) at what point the spark is initiated, but I think your electrics ability is up to that.
John |
Posted: Sat Feb 23, 2013 8:55 pm Post subject: Re: Initial timing |
| Farmer John wrote: | Hello Dave.
John |
Hi john
Its 5 degrees static timing for an MGA, but you cant simply do it with a lamp, when its an electronic distributer.
Farmer John
Posted: Sun Feb 24, 2013 12:00 am Post subject: |
There will be a switch to make and break the circuit which will have a measurable current. Generally the cam replacement will have a number of fins. As the leading edge of the fin intersects with the leading edge of the sensor, that is when the spark will occur.
John |
Posted: Sun Feb 24, 2013 11:19 am Post subject: |
Hi john
You are thinking of the dizzy's with optical sensors, my dizzy is hall effect. The dizzy needs to be turning to trigger hence the challenge for an initial static setting
welshrover
Posted: Sun Feb 24, 2013 10:03 pm Post subject: |
i just turn the engine over and turn the dizzy at the same time until it starts .if youve got a starter solonoid with the button on its easy ,or get somebody to turn the key. once running use a strobe light to set timing .5 degrees as stated before its the same as the oxford/cambridge etc.it works with electronic or points  |
