TM8
Posted: Tue Mar 05, 2013 8:41 am Post subject: Spring Hangers Morris 8 |
Hi, Took my Springs off the chassis last night to find oval hangers on the chassis. Has anyone succesfully repaired these. I had the idea of cutting the riverts on the chassis and taking it to an engineering works and having new ones made and then bolt them back to the chassis. Has anyone maybe got other ideas or success stories to share?
Regards |
Joined: 23 Nov 2007 Posts: 4264 Location: South Cheshire
Posted: Tue Mar 05, 2013 8:55 am Post subject: |
Yep thats pretty much what you have to do, there is a slight angle in them make sure this is correct. Some folk have had them cast in small volumes, others had the originals bushed. All refit with a nut and bold.
RUSTON
Posted: Tue Mar 05, 2013 11:50 pm Post subject: |
We used to do that on BMC trucks but we used to ream the holes out so that the bolts were a good tight fit otherwise they used to work loose in service.
Pete. _________________ Measure twice...cut once! |
Posted: Wed Mar 06, 2013 8:49 am Post subject: |
For some reason when I post with my Iphone it puts it in twice....probably user error  |
TM8
Posted: Wed Mar 06, 2013 12:46 pm Post subject: Repairing the spring |
| Also found the Spring ends them selves too have worn out does this mean a new spring leaf? |
Harry49
Posted: Fri Mar 15, 2013 10:16 pm Post subject: Repairing the spring |
I had all four springs reset and tempered by Brost Forge in London late last year.
Excellent service. Lovely bloke.
£380 for four. Like new. They have all the measurements etc. for Morris 8 springs.
Harry |
