What can cause drum brakes to squeal?
PostPosted: Fri Sep 09, 2016 5:41 pm    Post subject: What can cause drum brakes to squeal? Reply with quote
I rebuilt my Land Rover series 3 drum brakes with many new parts prior to the MOT test in May, and to start with performed as they should without so much as a peep.....
Gradually they began to squeak during braking, and this has since turned into loud squealing every time the brake is applied. I have dismantled and dusted them down, reassembled and adjusted, but still they squeal!
Any suggestions very welcome.
Thanks Steve
PostPosted: Fri Sep 09, 2016 7:49 pm    Post subject: Reply with quote
Have the shoes overheated and become glazed perhaps?
Kev
PostPosted: Fri Sep 09, 2016 9:15 pm    Post subject: Reply with quote
Hi Kev, thanks for your prompt reply.
No there was no sign of glazing over, besides, i wire brushed them off before refitting the drums, also there are chamfers at ends of the linings.
jp928
PostPosted: Sat Sep 10, 2016 2:58 am    Post subject: Reply with quote
Are there signs of the lining to drum contact not covering the the lining completely? Were the relined shoes radiused to the drum ? This involves running the shoes over a grinder so the linings have the exact same radius curved face as the drum. Should be done to suit each individual drum.
jp 26 Rover 9
PostPosted: Sat Sep 10, 2016 9:59 am    Post subject: Reply with quote
jp 26 Rover 9
Hi JP, no i didn't do that, and you could be onto something there, but you may need to explain the process to me in more detail..... Confused
PostPosted: Sat Sep 10, 2016 1:06 pm    Post subject: Reply with quote
It can be caused by having the wrong design shoe. i.e leading and trailing design compatible with the cylinder and pivot points.
jp928
PostPosted: Sat Sep 10, 2016 1:15 pm    Post subject: Reply with quote
When shoes are relined, assuming the new linings are exactly the same thickness as the originals, and the drums are still same diameter as new, all should be well. If the linings are different or the drums machined, the shoes need grinding. The drum dia is measured and a special machine set to that diameter, and each shoe (for that drum) is mounted and run past a grinding wheel so the effective radius of the shoe matches the drum exactly.
All the brakes on my car have been relined and machined before my time, so I may be confronted with the same issue.
This link may help
http://www.autoandindustrial.co.uk/index.php?webpage=radius-grinding
Note the bit at the end about shoes anchored at one end with a cam at the other needing special attention in this regard.
jp 26 Rover 9
PostPosted: Sun Sep 11, 2016 2:13 pm    Post subject: Reply with quote
Thanks jp, as new brake drums are just 13.50 each, i might try a pair of those next......
PostPosted: Sat Sep 17, 2016 1:53 pm    Post subject: Reply with quote
There WAS signs of glazing over, no doubt caused by the drum not matching the shoes profile as per JP's suggestion.......
New brake drums installed this morning, shoes de glazed,
and all is quiet now thank goodness!
Thanks all for your advice Cool Cool
Steve
PostPosted: Sat Sep 17, 2016 8:57 pm    Post subject: Reply with quote
Glad you are sorted Steve,
Nothing worse than noisy brakes.
Kev
BigJohn
PostPosted: Sat Sep 17, 2016 9:56 pm    Post subject: Reply with quote
Oh I don't know, I'd take noisy brakes over no brakes.
(sorry couldn't resist, I'll get my coat) Laughing
