rcx822
Posted: Sun Sep 11, 2016 9:26 am Post subject: Anyone fitted electric power steering? |
Has anyone had experience of fitting electric power steering? I've found some kits online, the last one was £1500. I'm wondering if an OEM unit from a modern car could be hacked to work in a car that never had any power steering. |
Joined: 20 Aug 2008 Posts: 1177 Location: Netherlands
Posted: Sun Sep 11, 2016 10:55 am Post subject: |
Yes. I had a company for a few years and we specialized in this. Fitted it to many many classics (MGB, Amazon, XK150, E-type, Jag Mk2, Alfa 2600, GTV and Berlina, Cadillac 60, Morgan, Chevy pick up, Wolseley 6/110, Aston DB4, Bentley Mk IV, Silver Cloud I, Saab 99, TR3, Mercedes 308 van, and many more).
We had a special (expensive!) insurance in case accidents were caused by our installed systems in cars from clients.
The units we used are OEM from for example Corsa, Clio and C1. The Corsa unit is the most powerful, it can cope with the heavy cars but it also the most bulky.
The EPS needs a controller and a ECU to operate. The controller feeds the EPS, this is not OEM as in original fitment the ECU gets its information from original sensors in the car. So, while you maybe can get cheap units from scrap cars (risky business) you still would need a controller. These are available from Ebay sellers for around 30 pounds.
BUT it is not a simple case of getting a kit and DIY install it. The unit needs to be fitted to the steering shaft which means precise cutting the shaft and welding adaptive ends to fit the EPS unit. Needless to say this is not something to be taken lightly as it concerns a primary safety function of a car - steering. Sturdy brackets will need to be tailor made to fit the EPS unit to a solid part of the car.
I would suggest you would at least need to have (access to) a lathe, good welding and electrical skills.
That said, I feel it is much an improvement for many cars. While I would not think of fitting a unit to my TR4 (we did this for a customer though, an older gentleman who had lost strength in his arms), in the Westminster for example it is a great success. It has turned the car is a much easier manouvrable car. Also in a XK150 it will transform the car.
My opinion of course, we always had many discussions with clients about the pros and cons. Each to their own I would think. _________________ a car stops being fun when it becomes an investment |
rcx822
Posted: Sun Sep 11, 2016 5:15 pm Post subject: |
Hi Badhius,
That's great information.
The physical installation I'm savvy with, I can modify shafts, cut spines etc. It's the electrical side that concerns me. I just don't want to have to spend countless nights researching how to make it work as I've got a dozen other such tasks to do already on my project.
So the controller I can buy aftermarket. But how does the controller integrate with the ECU? Does it have to be compatible with the specific ECU that the car is running? What if there's no ECU?
This is for a kit car that will be running a Lexus V8 engine with OEM ECU (i.e. the ECU is also from a Lexus). |
rcx822
Posted: Sun Sep 11, 2016 5:29 pm Post subject: |
Badhius, when you say I will need an ECU, do you mean the main Corsa (or other) ECU that the EPAS motor came from? Or do you mean that there is a dedicated EPAS ECU on the Corsa (I'm probably going for the Corsa unit).
Also, Google says that the aftermarket controller mimics the speed and RPM signal that would normally go to the ECU. But the aftermarket controllers won't vary the signal so you get a constant amount of power steering help. If this is right then did you ever take things further by actually sending a true RPM and speed signal to get variable power steering force? |
Joined: 25 May 2011 Posts: 2002 Location: South Cheshire
Posted: Sun Sep 11, 2016 6:22 pm Post subject: |
I briefly looked at this for my current restoration, I think the idea of the control box is to allow the variable assistance but the cheap ones are (or were) adjusted manually by a control on the box to turn it up or down. |
goneps
Joined: 18 Jun 2013 Posts: 602 Location: Auckland, New Zealand
Posted: Mon Sep 12, 2016 12:49 am Post subject: |
Just a word of caution. My Corolla has electric power steering, which I didn't realise until after I'd bought it. While it's fine around town, on motorways it's wooden, unresponsive, and totally lacking in feel. The result is that it requires constant concentration and is therefore quite tiring.
Fortunately this has not been a serious issue because the car never goes outside Auckland. My conclusion is that whereas hydraulic power steering has been developed to a fine degree of weight and responsiveness, electric systems have yet to achieve the same level of refinement.
Richard |
Joined: 26 Jan 2012 Posts: 1474 Location: Above the snow line in old Monmouthshire
Posted: Mon Sep 12, 2016 10:10 am Post subject: |
goneps wrote: | Just a word of caution. My Corolla has electric power steering, which I didn't realise until after I'd bought it. While it's fine around town, on motorways it's wooden, unresponsive, and totally lacking in feel. The result is that it requires constant concentration and is therefore quite tiring.
Richard |
I wouldn't assume they're all like that. I have a 2001 Corsa for everyday use and have been pleasantly surprised by the power steering on that - once I got over the culture shock of having it at all! It's very light at low speeds and makes parking a doddle, but doesn't feel excessively light at speed. I see Badhius mentioned Corsa units earlier in the thread, perhaps they're uncommonly good for what they are? |
Posted: Mon Sep 12, 2016 11:21 am Post subject: |
This might not be directly applicable to anyone on here thinking of doing this, but, when thhe electric PSv started appearing on Corsas etc driving instructors were reporting that they were incapable of doing more than 2 or 3 Turn in Road manoeuvres consecutively,
Apparently the motors were overheating. _________________ Bristols should always come in pairs.
Posted: Mon Sep 12, 2016 12:04 pm Post subject: |
How do insurers view these modifications - is it ok to do this at home, maybe with an engineer's report, or can it only be done by an approved specialist? Just curious.
rcx822
Posted: Mon Sep 12, 2016 3:23 pm Post subject: |
Rick wrote: | How do insurers view these modifications - is it ok to do this at home, maybe with an engineer's report, or can it only be done by an approved specialist? Just curious.
RJ |
I must have thirty modifications done to my jeep ranging from brakes to suspension and the insurance is cheaper than an unmodified car of the same model despite the value being higher. I guess that the insurers now recognise enthusiasts that they deem to be relatively safe. Hasn't this always been the case with classic car owners as well?
In terms of legality, the modifications must continue to meet construction and use. I'm not sure how construction and use ties in with EU type approval though. And I guess they must meet the construction and use rules of the year the vehicle was registered.
I heard something about "boy racer" type modifications, like stretched tyres, or some of the brake modifications that they do, are dangerous and that these lead to the attempt to implement German type rules that vehicles cannot be modified except with type approved parts (which need to be type approved to the vehicle). The government (or was it the EU) withdrew this proposed legislation before it ever became law. |
Posted: Mon Sep 12, 2016 7:40 pm Post subject: |
Penman wrote: | Hi
Apparently the motors were overheating. |
I bet that was welcomed by people living on quiet backstreets near driving test centres...  |
