trampintransit
Posted: Fri Dec 02, 2016 8:35 pm Post subject: Starter motor dissasembly... |
[img]http://s357.photobucket.com/user/Guy_Satchwell/library/starter[/img]
How on earth do I get this apart in order to extract the mounting plate? _________________ '60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
Penguin45
Posted: Fri Dec 02, 2016 9:18 pm Post subject: |
Remove snap ring ( 2 ). Compress dog assembly and remove Woodruff key ( 18 ). It should all then just pull off.
Posted: Fri Dec 02, 2016 10:27 pm Post subject: |
Guy,
Which car is this info for? If it's the Jaguar then this diagram doesn't apply.
Art |
Penguin45
Posted: Fri Dec 02, 2016 10:39 pm Post subject: |
Looks very like an M35 starter motor to me.
trampintransit
Posted: Sat Dec 03, 2016 1:00 am Post subject: |
It's off the Armstrrong Siddeley. I didn't see any evidence of a woodruff key in the end of the sleeve. The sleeve has flats so I assumed it threaded off the shaft. Snag is, ~I couldn't work out if it's L or R hand thread ... anyway ...it doesn't seem to want to budge?
edit ... this one was donated to me 'cos the one on the car , whilst it works has one of the bolt hole ears broken off. I though I'd swap the mounting plate of this one but it's defesated me thus far. _________________ '60 Armstrong Siddeley Star Sapphire
trampintransit
Posted: Sat Dec 03, 2016 1:12 am Post subject: |
ah ..part 6 or 34 in the diagram may be the answer ....I would have thought I'd have spotted a pin though .....back in the garage on Monday for another look.
But I found this ...very useful ....suggests it's an M45G
http://classicvehicledata.com/wp-content/uploads/2013/01/lucasstarters46to60.pdf _________________ '60 Armstrong Siddeley Star Sapphire
