ATF...
trampintransit
PostPosted: Wed Jan 04, 2017 11:20 pm    Post subject: ATF... Reply with quote
...So the manual says Shell Donax T6 / Castrol TQ / EssoAutomaticTransmission 55 / Energol ATF type A ...
What's the modern equivalent of that? Will Dexron 11/111 be ok?
It's for a BG box in an Armstron Sideley Star Sapphire?
'80 Reliant Scimitar
PostPosted: Thu Jan 05, 2017 1:38 pm    Post subject: Reply with quote
There was a similar discussion on here back in April 2009, but I reckon that that was pretty inconclusive. Personally I would put a call in to Millers or similar who have a significant interest in classic oils and ask their advice
PostPosted: Thu Jan 05, 2017 2:39 pm    Post subject: Reply with quote
Some sound advice from Paul. Many of the postings on OCC reveal manufacturers and specialists as an under used source of specialist information.
Posting informative replies with due acknowledgement may be useful to other OCC members.
V8 Nutter
PostPosted: Thu Jan 05, 2017 8:27 pm    Post subject: Reply with quote
In American cars type A has been replaced by Dextron. Dextron II should be O.K. Dextron III is more suited to heavy duty applications, but as the others have said it always best to check with a specialist
PostPosted: Thu Jan 05, 2017 9:04 pm    Post subject: Reply with quote
V8 Nutter wrote:
Dextron II should be O.K. (...)
But it wasn't too common when I was looking for some about 8-10 years ago, so I suspect you may struggle to find it now.
trampintransit
PostPosted: Sat Jan 07, 2017 1:13 am    Post subject: Reply with quote
I've got an unopened cntainer of Comma AQM mineral Dexron 11 / 11D .... I've emailed Aylesbury classic oils to ask him .....I'll let you know.
PostPosted: Sat Jan 07, 2017 10:10 am    Post subject: Reply with quote
You can still buy ATF oil, such as here:
http://www.morrislubricants.co.uk/catalogsearch/result/?cat=0&q=atf+oil
or here:
http://www.opieoils.co.uk/c-1432-atf-automatic-transmission-fluid.aspx
and lots of other places too no doubt Cool
V8 Nutter
PostPosted: Sat Jan 07, 2017 3:59 pm    Post subject: Reply with quote
Useless information for you. The original Type A atf was phased out because one of it's main ingredients was whale oil.
PostPosted: Sat Jan 07, 2017 6:06 pm    Post subject: Reply with quote
When I was at school, late 50's, we did projects about whaling and whale factory ships.
ajlelectronics
PostPosted: Sat Jan 07, 2017 6:25 pm    Post subject: Reply with quote
Dextron III is backwardly compatible with the two previous versions. However, many older gearboxes tended to use mineral type F/G AQF, examples being the Ford C3 and Borg Warner 35 as fitted to UK Fords etc.
Therefore I would want to be certain as using Dextron in a type F/G box would be disastrous.
Evans Waterless Coolants
trampintransit
PostPosted: Thu Feb 16, 2017 10:48 am    Post subject: Reply with quote
It's a Borg Warner DG... The consensus seems to be dextron ll is correct oil.
