GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Sun Sep 17, 2017 12:57 pm Post subject: |
Richard H wrote: | That looks seriously lovely. Top work so far. |
H,
thank you for the complement,
as these thing's tend to , it's taking me a lot longer to sort this car out, everything mechanical on it is either out of adjustment or u/s, plus doing a few mod's on it pushes the finish date further away, good job i'm not in a rush,
a few people mentioned that with the 175 radial tyre's on it, the steering would be heavy, well, i pushed it about on the driveway to get it in a better position to get it up on the four axle stand's, and even with the 12" mountney steering wheel i've put on, it was surprisingly easy, plus i couldnt believe how light these car's are, really easy to push about, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Mon Sep 18, 2017 7:32 pm Post subject: |
oil level gauge bolted on and level marked on sump in white paint,
russian image host _________________ 1957 - 103e - popular,
Last edited by GARAGE HERMIT on Thu Sep 20, 2018 12:56 pm; edited 1 time in total |
Paul fairall
Posted: Mon Sep 25, 2017 6:51 pm Post subject: |
Tell me more about the level gauge, indicator whatever. _________________ 1957 ford popular |
GARAGE HERMIT
Posted: Tue Sep 26, 2017 10:29 pm Post subject: |
Paul fairall wrote: | Tell me more about the level gauge, indicator whatever. |
i'll find the box it came in, to let you know the part No, etc, i bought it from my local tube shop, braided, steel, etc,
all you do is drill two hole's in the sump, and bolt it on, easy, i poured 5 pint's of water into the sump, to find the level, to mark on the outside, now fitted, work's fine,
GARAGE HERMIT
Posted: Tue Sep 26, 2017 10:42 pm Post subject: |
drained the g/box oil, jeeze, what a terrible colour, dont think it had been changed for year's,
while i had the drain plug out, installed a 1/4" x 1/2" magnet,
g/box mount's installed, the old one's were perished and the bolt's were loose with cotter pin's missing,
inline petrol filter fitted, wired up the water temp gauge, let the engine run for a while, not quite reading normal, so i'll have to fiddle with some more resistor's,
GARAGE HERMIT
Posted: Wed Sep 27, 2017 8:40 pm Post subject: |
my really old camera, cant take close up pic's,
here's the part number etc,
1910000086
SNA 076 B-S-O-10
made by STAUFF
just google it, to find your nearest stockist, it cost about £15.00 _________________ 1957 - 103e - popular, |
Joined: 23 Nov 2007 Posts: 4751 Location: Swindon, Wilts.
Posted: Wed Sep 27, 2017 9:14 pm Post subject: |
You mentioned drilling 2 holes for the bolts, but how does the oil get into the tube to show the level? _________________ Bristols should always come in pairs.
GARAGE HERMIT
Posted: Wed Sep 27, 2017 10:36 pm Post subject: |
Penman wrote: | Hi
You mentioned drilling 2 holes for the bolts, but how does the oil get into the tube to show the level? |
the bolt's are hollow, ie banjo bolt, they come with the gauge, _________________ 1957 - 103e - popular, |
Paul fairall
Posted: Sat Sep 30, 2017 8:10 pm Post subject: |
GARAGE HERMIT wrote: | oil level gauge bolted on and level marked on sump in white paint,
| i assume you used thread lock on the bolts. You wouldn't them to come out. I think I would drill and wire the nuts to the bolts. _________________ 1957 ford popular |
GARAGE HERMIT
Posted: Sat Sep 30, 2017 8:37 pm Post subject: |
Paul fairall wrote: | GARAGE HERMIT wrote: | oil level gauge bolted on and level marked on sump in white paint,
| i assume you used thread lock on the bolts. You wouldn't them to come out. I think I would drill and wire the nuts to the bolts. |
i used spring washer's with green studlocker,
good idea the safety wire, never thought of that, _________________ 1957 - 103e - popular, |
Posted: Sat Sep 30, 2017 8:55 pm Post subject: |
Instead of drilling through the bolts, drill between adjacent flats which should miss the thread, then use locking wire between the 2 nuts in a direction which doesn't permit slackening.
Of course if the nuts are wired you also need to wire the bolt heads.
http://avstop.com/ac/apgeneral/safetymethods.html _________________ Bristols should always come in pairs.
Paul fairall
Posted: Sat Sep 30, 2017 9:21 pm Post subject: |
That is why I suggested drilling through the the bolt and nut. The bolts are only holding the indicator against the sump and gasket. Hardly any stress on them.
Better still make a tab washer to encompass both bolts like brake disc rotors on bicycles were done in the past. _________________ 1957 ford popular |
Posted: Sat Sep 30, 2017 10:11 pm Post subject: |
In the long distant past didn't someone invent a "dipstick" |
Paul fairall
Posted: Sun Oct 01, 2017 8:24 am Post subject: |
peterwpg wrote: | In the long distant past didn't someone invent a "dipstick" | had you read the thread Peter you would know that with the twin su's and aquaplane manifolds it's not possible to keep the dipstick. This may be when the aquaplane head is used as I haven't fitted my su's yet and don't know if it's possible to get the dipstick out. I wonder if it's possible to bend the dipstick tube so the dipstick can be got at. _________________ 1957 ford popular |
Posted: Sun Oct 01, 2017 7:00 pm Post subject: |
There are flexible ones, dipstick. |
