Just bought a Pop 103e, 1957
Goto page Previous  1, 2, 3 ... 15, 16, 17
GARAGE HERMIT
PostPosted: Mon May 14, 2018 11:47 pm    Post subject: Reply with quote
thank's alanb,
i've just been reading up on the MG to VW s/box swap, sound's ok, so i bought a VW s/box of ebay, it's just a second hand one to have a look and see if i can make it work on the pop, then buy a new one about 150.00, which will be worth it for my nerve's,
i've installed all new trackrod end's plus drag link end's, so there's no play after the s/box,
i set the tracking up using a lazer measuring tool so i know that's ok, the camber and castor as far as i know is non-adjustable,
to be continued, lol,
1957 - 103e - popular,
alanb
PostPosted: Tue May 15, 2018 9:24 am    Post subject: Reply with quote
Good luck I hope the VW box does the trick.
old tourer
Morris 8 two seater
GARAGE HERMIT
PostPosted: Fri Jun 01, 2018 12:59 am    Post subject: Reply with quote
when i recieved the vw s/box and had a good look at it i noticed the output shaft only allowed the drag link arm to go on one way, of course it pointed it the opposite direction that i needed, so i stripped it down and reversed the gut's in it, drilled a hole in the large adjuster on it and it will work on the pop, i've still to modify the drag link arm and make the mounting bracket for the s/box to the chassis, plus i'll have to buy a vw drag link cross shaft as the pop ball joint taper is too small for the vw drag link arm, also bought a porsche uj knuckle joint steering shaft part, just in case the s/box when fitted doesn't line up with the pop steering column, a lot of work but i'm just not comfortable with 2" of play at the pop's s/wheel, the vw s/box is very beefy compared to the pop and is adjustable for play on the input and output shaft's too,
this is the modified s/box,
GARAGE HERMIT
PostPosted: Fri Jun 01, 2018 1:03 am    Post subject: Reply with quote
wondered what the hole on the wiper blade was for till i noticed an ad on ebay for wiper securing rubber pin's, now i know, lol,
GARAGE HERMIT
PostPosted: Thu Jul 05, 2018 5:19 pm    Post subject: Reply with quote
the point of no return, chopped the steering box off the steering column,
GARAGE HERMIT
PostPosted: Thu Jul 05, 2018 5:29 pm    Post subject: Reply with quote
had the mounting tube machined up that the s/box clamp's to,
trimmed the pitman arm down,
bought a VW trackrod end as the pop one was too small for the VW pitman arm,
flange for joining pop s/column to VW box,
still a few bit's to be machined and the plate's to mate the s/box to the chassis to make and weld, but it's getting there,
consul 57
PostPosted: Fri Jul 06, 2018 7:03 pm    Post subject: Reply with quote
nice work
GARAGE HERMIT
PostPosted: Tue Jul 31, 2018 9:12 pm    Post subject: Reply with quote
made the u-shaped s/box mounting bracket out of 3/8" steel plate, lining it all up to mate with the pop steering column and getting the pitman arm in the right position was a right mess on though, getting closer to being done,
GARAGE HERMIT
PostPosted: Tue Aug 07, 2018 10:27 am    Post subject: Reply with quote
different take on a pop, not mine by the way,
GARAGE HERMIT
PostPosted: Wed Aug 08, 2018 9:00 pm    Post subject: Reply with quote
picked up my bit's from the machine shop, started adding them to the pop steering part's,
GARAGE HERMIT
PostPosted: Thu Sep 20, 2018 12:47 pm    Post subject: Reply with quote
VW s/box etc all installed and working fine, no play at all at the steering wheel, now just have to trace a missfire and tune the twin SU's, oh and finish the interior and fit the watts linkage to the rear axel, etc, etc,
GARAGE HERMIT
PostPosted: Thu Sep 20, 2018 1:14 pm    Post subject: Reply with quote
started re-uploading some of the pic's in previous post's that disappeared, cant find all of them but i'll post as many as i can find,
pic image upload
Paul fairall
PostPosted: Wed Sep 26, 2018 8:30 am    Post subject: Reply with quote
Lovely car, is that a standard roof or glass fibre insert panel.
1957 ford popular
GARAGE HERMIT
PostPosted: Wed Sep 26, 2018 1:08 pm    Post subject: Reply with quote
standard leathercloth stuff,
Paul fairall
PostPosted: Thu Sep 27, 2018 4:05 pm    Post subject: Reply with quote
Ok, doesn't lay any flatter than a glass fibre replacement. The rubber seal channel is rusted badly on mine so I bought the grp panel that covers the rust completely and has a rubber seal around it. Need to paint the roof before fitting the seal, so for now it's just screwed in place.
1957 ford popular
Page 17 of 17
