Paul fairall
Posted: Sun May 07, 2017 9:20 pm Post subject: Cannot turn distributor ford pop 103e |
Fitted electronic ignition to my 10hp sidevalve and found the distributor cannot be turned to set the ignition timing. Clamp turns but dizzy is solid. Sprayed with liquid spanner but no go. Will continue to soak it the next few days. Looks like I may need to remove the carb to get at it. Anyone had this problem and can advise. _________________ 1957 ford popular |
Posted: Sun May 07, 2017 10:13 pm Post subject: |
Paul,
You don't have access to a big Stinson type pipe wrench do you? You could grab the distributor body down low with that and lever it around.
Art |
Paul fairall
Posted: Sun May 07, 2017 10:49 pm Post subject: |
Yes Art I do have 24" stilsons, is the dizzy strong enough to do that? _________________ 1957 ford popular |
Posted: Mon May 08, 2017 11:12 am Post subject: |
Maybe try a bit of heat on the head. Ideally oxy-acetylene but propane might work.
Posted: Mon May 08, 2017 11:48 am Post subject: |
Paul,
From memory the case is cast iron and down at the bottom where the sides end should be strong enough. I don't think it would take much to move and if it does DESIST.
Art |
Paul fairall
Posted: Mon May 08, 2017 4:18 pm Post subject: |
| Rick wrote: | The little adjustment screw that screws into the head, where the adjustment scale is, has also freed off ok?
RJ | yes screw loose and clamp and the clamp turns freely but not the dizzy. _________________ 1957 ford popular |
Paul fairall
Posted: Mon May 08, 2017 4:22 pm Post subject: |
As I said will spray it with release oil a few times and try to move it. If not will leave well alone until I have the engine out and head off. Don't fancy oxy-acetylene on it while it's in the car and fixed to the block. _________________ 1957 ford popular |
Joined: 14 Oct 2016 Posts: 2192 Location: East Yorkshire
Posted: Mon May 08, 2017 5:49 pm Post subject: |
Hi.the head is simple to remove without removing the engine. [just buy a new gasket]....it's only a lid, after all....  |
Paul fairall
Posted: Mon May 08, 2017 6:02 pm Post subject: |
I've got enough to do with body repairs and want to keep it in running order for the summer. It's running fine as is. _________________ 1957 ford popular |
