Sealing timber body frame - what to use?
greenbeam
PostPosted: Fri Apr 27, 2018 12:36 pm    Post subject: Sealing timber body frame - what to use? Reply with quote
Hi All,
I would like to use some kind of coating to seal parts of the timber body frame of my 1935 Armstrong Siddeley before I refit the metal body panels. What have people used to seal the timberwork - paint (what kind), some specialised coating, I've heard of blackboard paint (why???).
I am specifically concerned about the timber around the windscreen, with the openings for wipers, the hinged windscreen etc.
Any first-hand experience most valued.
Regards,
Paul.
1963 Sunbeam Alpine Series 3
1935 Armstrong Siddeley 17HP Sports Saloon
1935 Armstrong Siddeley 17HP Coachbuilt Saloon
Billf
PostPosted: Mon Jul 16, 2018 11:36 am    Post subject: Reply with quote
Hi Greenbeam.
The best to use would be a clear "Thin" spirit based wood sealer, as this would soak into the timber, Sadolin do a range of wood stains in clear and colours. try and put as many coats as you can even more on the cut ends and it will soak in. If you use water based sealer this would bring up the grain.
Cheers. Bill.
https://www.screwfix.com/c/decorating/wood-stain/cat850456
