1953 Volvo PV444
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Oct 30, 2019 11:33 pm    Post subject: Reply with quote
norustplease wrote:
Car is looking good.
In fairness the paint isn't too pretty close in, but it was bought to use so, meh. Ploughing through a particularly deep puddle in it the other day raised a few eyebrows with others who were pontificating about trying their luck. There's still a modern BMW sat in a layby, where it had been dragged to after packing up in the middle of this sizeable puddle on Saturday. The other BM that was dumped in front of it has disappeared now.
Rick (OCC Admin)
norustplease
PostPosted: Thu Oct 31, 2019 10:11 am    Post subject: Reply with quote
There was something on Pistonheads about this a couple of years ago. Apparently 5 Series were particularly bad, having low mounted air intakes. Someone quoted his manual as saying that max wading depth for his 3 Series was 25 cm (about 10 inches) at max 3 mph!
The air cleaner intake on my 544 is quite high up and the distributor is probably at risk before water is ingested.
1953 Citroen Traction
1964 Volvo PV544
1986 Renault 4
1990 Citroen 2CV
Boring Fiat 500X
Mosquito
PostPosted: Sat Nov 23, 2019 7:24 pm    Post subject: Reply with quote
The letter K refers to the swedish petrol company Koppartrans (1947 - 1963).
PostPosted: Sat Nov 23, 2019 8:10 pm    Post subject: Reply with quote
Ah righty, many thanks!
Rick (OCC Admin)
PostPosted: Mon Jan 20, 2020 4:04 pm    Post subject: Reply with quote
The 444 was treated to an oil and filter change over the weekend, making the most of the relatively mild weather. It's a satisfying feeling using something out of a manufacturer-branded box, rather than aftermarket, in this case a Mann filter in a Volvo box.
Rick (OCC Admin)
PostPosted: Mon Feb 10, 2020 10:57 pm    Post subject: Reply with quote
Rick. What oil are you using?
I am unsure which oil to use in my rebuilt MG engine. As the engine is clean perhaps a synthetic oil would have an advantage. It shouldn't require such frequent changes as mineral oil. but....
The dilemma I have is that I will need to run in the engine. Can you get synthetic oil for that?
Fully synthetic oil is expensive - especially if you are not going to use it for many miles.
PostPosted: Tue Feb 11, 2020 8:38 am    Post subject: Reply with quote
It may be different for a rebuilt engine, but I'll just continue using mineral 20/50 in the Ovlov and change it on a regular basis.
Rick (OCC Admin)
PostPosted: Tue Feb 11, 2020 9:28 am    Post subject: Reply with quote
Ray,
Get the cheapest rubbish for running in then transfer to fully synth. I use Ford Formula F which is available on line at reasonable prices.
1939 SS Jaguar 2 litre saloon
PostPosted: Tue Feb 11, 2020 10:08 am    Post subject: Reply with quote
I discovered a piece of steel swarf while fitting the camshaft so I am wondering if there is any more that has escaped the cleaning process?
I will be running with a modern disposable canister type oil filter that fits inside what looks like an original style outer canister and I have also invested in a new magnetic sump plug just in case but I was going to buy one anyway.
In addition, I have bought a clever devise that you can use to adjust the oil pressure. It is much more convenient than fiddling about with different pressure relief springs.
I will also have a new oil pressure gauge so hopefully covered all the weak points of the system.
I used Millers 'running in' oil in the Dodge engine. I may use it again just to be on the safe side.
This XPAG engine is costing so I need to take care with the oil.
PostPosted: Thu Feb 27, 2020 10:33 am    Post subject: Reply with quote
During a (scheduled) power cut yesterday, I was stuck here with very little to do, bar keep an eye on the 240v generator that we had running to keep the cellar pump and fridge/freezers working. So it seemed like a good time to scrape off caked-on muck and grease from the 444's front suspension. By torchlight.
I've been putting this off for a while, but it had to be done, and now it's all cleaned up and looking a lot more presentable.
Next will be to check each grease nipple then give the front end a much-needed greasing.
Rick (OCC Admin)
PostPosted: Thu Feb 27, 2020 11:23 am    Post subject: Reply with quote
What grease will you be using, Rick? There seems to be so many different options these days I am a bit confused. Confused
PostPosted: Thu Feb 27, 2020 11:32 am    Post subject: Reply with quote
Whatever's on the shelf, something "in period" I'm sure Smile
Rick (OCC Admin)
PostPosted: Sat Mar 14, 2020 1:43 pm    Post subject: Reply with quote
A few days back I gave the Volvo an airing, its first proper warm-through since changing the oil. I was surprised to see that on my return, with it fully warmed up, there was an oil haze from the exhaust, increasing quite noticeably when revved. Previously, there had been nothing.
For the recent oil change I used Comma 20/50 classic oil, a tin of which I had on the shelf. On reading around after seeing this haze, I found other people commenting how they'd have to top up more often than usual when using Comma, and that the pressure didn't stay as high as some other oils once the engine was warm.
I'm sure I used Comma in the Moggy with no ill effects, but given that there was no oil burning with the Volvo prior to the change (I don't know what make of oil the previous owner had used), I decided to try a different brand. I'd read positive things about Heritage Classic Oil, so thought I'd give that a try today.
Touch wood, the oil haze has disappeared again, even after a spirited run for a few miles. Why the Volvo didn't seem keen on Comma, yet the Moggy was fine, I'm not sure, but I'll keep an eye on the oil level going forward, and see how it goes on this fresh lubricant from Mr F Thownsend's emporium.
Rick (OCC Admin)
PostPosted: Sat Mar 14, 2020 2:00 pm    Post subject: Reply with quote
That is worth remembering, Rick.
You can never be sure. I once switched to Castrol GTX in a Vauxhall Astra.. It had never used oil until I put that in it ...and it continued to drink oil even when I went back to the original brand.
(It was my wife's car and she gave me grief... but that's another story. Ohhhhh! Crying or Very sad )
PostPosted: Sat Mar 14, 2020 2:11 pm    Post subject: Reply with quote
Also from reading around elsewhere, it's been suggested in various places that Halfords classic 20/50 is produced by Comma and simply put into a Halford tin.
Rick (OCC Admin)
Page 4 of 5
