alanb
Posted: Thu Sep 10, 2020 6:29 pm Post subject: Old engines |
A friend of mine is having a clear out of his many sheds and lean to’s, he has a number of old stationary engines and a couple of what look like Austin 10 engines and a couple of what he believes Austin A40 Devon engines all have been stood in not ideal conditions for 30 years or more. My question is do the members of this forum think they have any value and are worth saving? If so does anyone have any idea of what they would be worth? _________________ old tourer
Morris 8 two seater |
Posted: Thu Sep 10, 2020 7:23 pm Post subject: |
Last year I sold a cache of Austin Seven spares including an engine and gearbox.
I accepted £100 for the lot (quite a lot actually) because I knew the young chap was restoring his Grandfather's Seven. No doubt I could have got quite a bit more if I had advertised it on Ebay
I think the degree of corrosion must be taken into account with the engines you mention. |
alanb
Posted: Thu Sep 10, 2020 7:56 pm Post subject: |
At the moment I can’t get close enough to assess their condition but from ten feet they look pretty rusty, but it maybe mostly surface rust. Once we can get them out I’ll be able see if they can be turned by hand, it’s just I’d hate to see them go to scrap if they could be of use to someone, if the blocks are sound they may help someone out of trouble. _________________ old tourer
Morris 8 two seater
Posted: Thu Sep 10, 2020 10:19 pm Post subject: |
I am reminded of when the famous yard at Adversane was being cleared. There was a trailer container filled to the top with ancient aluminium crank cases and gearboxes. I was told if there was anything I wanted I should grab it before it was sent away as scrap.
It was quite sickening but I had no means of lifting such heavy parts so I had to walk away.
today, I expect a crank case for an Edwardian car would set you back thousands. |
lowdrag
Posted: Fri Sep 11, 2020 9:55 am Post subject: |
And at Stickley's yard in the Midlands, it should be remembered that about 30 years ago they found part of the cut-up remains of the Jaguar prototype E1A. After changing hands a few times and nothing being done, it is now slowly being rebuilt. And they've even got the registration back!
Clactonguy
Joined: 20 Mar 2018 Posts: 104 Location: clacton on sea
Posted: Fri Sep 11, 2020 5:51 pm Post subject: engine parts? |
a picture tells a thousand words. showing a couple and seeing if any interest is best way to start.value is significantly affected by condition .eg no turning of crank? surface rust is ignored as is paint and unless we can identify parts ? we face endless question from anybody remotely interested. Local interest is best of course as possible to pop round for a dekko? submitting pics and asking for interest or offers from local car clubs ? museums? might get ball rolling. |
