Posted: Fri Jun 11, 2021 10:10 am Post subject: |
Bitumen Boy wrote: | That's looking really good. Nice work |
Well the bits I can see look good.
Posted: Sat Jun 12, 2021 2:04 am Post subject: |
peter scott wrote: | Bitumen Boy wrote: | That's looking really good. Nice work |
Peter |
Thats the way it always is with oldies, surely..? |
Miken
Posted: Thu Jun 24, 2021 8:59 pm Post subject: |
After 3 weeks work , here it is all back together and back on the road. Ive been using it all week for getting around.
In the end I stripped the door and wing as well. Gave it all a few coats of epoxy primer and a single temporary coat of green cellulose to make it a bit more presentable. Eventually it will all get flatted down and the various repairs will receive a proper top coat all over .
Ive still got to do the other side (here) which should be the last bit of bodywork, but I think Ill give it a rest for a month or 2 and get a few more miles on it this summer. At least I will know how to tackle it this time.
Miken
Posted: Sat Jun 26, 2021 8:23 pm Post subject: |
Today was an interesting day I got to try out 3 new vehicles.
So, In preparation for passenger hauling hopefully starting shortly after the lifting of covid restrictions at the railway:-
1) I was able to try my freshly repaired truck towing a trailer for the first time.
2) I was able to try out the new trailer.
And
3) I was able to get a boiler test and try out my rebuilt locomotive at my club.
The car and trailer performed well. I like it when my truck to has an actual, useful job to do.
The loco passed its boiler test but suffered a slight derailment of the front bogie. So needs a bit more work on the suspension to rectify this problem before going into service.
Miken
Posted: Thu Jul 08, 2021 11:02 pm Post subject: |
I stopped at the level crossing in Newhaven last Monday. A pedestrian started the usual shouted conversation. "That's nice mate, how old etc".
Then he said something I wasn't expecting.
"Are you an ex para? "
Me, "err, no, why?"
" Oh, just wondered, cos you've got para wings on your hubcaps, I'm ex 2 para".
Eh??
Then I realised what he meant. I suppose the embossed Austin logos do look a bit like the regimental badge (from a distance if you squint). |
Miken
Posted: Thu Jul 15, 2021 9:53 pm Post subject: |
Today I thought I would try a little modification to the steering on my truck.
I have read about a conversion that MG and Austin healey owners do that involves replacing the thrust washer arrangement with a thrust needle roller bearing to make the steering lighter at low speeds. My steering isnt at all bad but I thought I would see if it could be better.
The standard arrangement consists of 2 steel washers with a sintered broze washer sandwiched in between at the top of each king pin. These takes the weight of the car on both sides at the front.
I bought the 3 piece bearings from "simply Bearings" for £3.02 each.
Dimensions are 20x35x4 and are the same as the ones in the MG/Healey kits.
The standard bearings are about 8mm thick so a packing piece is required for the needle bearing to make up the difference.
I incorporated an o-ring in the OD of the packing that allows excess grease out but hopefully not grit in. I dont think the bought kits have any sort of seal. But then neither does the original arrangement and they last for years.
I made the packer from bronze, but steel or even alloy would do.
It all came apart surprisingly easily and I did it all this afternoon.
I excitedly took it for a test drive after dinner and......
The steering is hardly any different!
Well maybe its a bit lighter.
Posted: Thu Jul 15, 2021 10:29 pm Post subject: |
I replaced the thrust washers with needle roller bearings on my MG TC.
The king pins and bushes needed replacement so I did this mod at the same time.
The only draw back as far as I can see is there is no obvious provision for lubrication. |
Miken
Posted: Fri Jul 16, 2021 6:13 am Post subject: |
Ray White wrote: | I replaced the thrust washers with needle roller bearings on my MG TC.
On my arrangement the new thrust bearings are lubricated by the in the normal way via the grease nipple. |
Posted: Fri Jul 16, 2021 12:06 pm Post subject: |
Miken wrote: | Ray White wrote: | I replaced the thrust washers with needle roller bearings on my MG TC.
Same as me. After I had done it all some bright spark thought they would make my day by pointing out that the original bronze thrust washers are grooved
to permit greasing and that the Torrington bearings are sandwiched between hardened washers which stop grease getting to them.
Whether or not this is true, I am not changing it now. I take the view that if grease can't get in then the grease already there can't get out... so they stay greased. |
Miken
Posted: Wed Jul 21, 2021 10:16 pm Post subject: |
Ive now driven a couple of hundred miles over the last week with the new king pin thrust bearings.
The steering is definately lighter at low speeds.
Although not "power steering" light as I have seen claimed.
But its a quick, straightforward and cheap enough mod to do (especially if you DIY it), so Im pleased i did it. |
Miken
Posted: Sat Jul 31, 2021 8:16 pm Post subject: |
Earlier this week I was poking around with a screwdriver at the left hand side of the cab.
I got a bit carried away and now im doing this:
Posted: Sun Aug 01, 2021 1:59 pm Post subject: |
Excellent repair. Good to see someone not to be afraid to use the welding machine. Thank you for sharing with us. _________________ a car stops being fun when it becomes an investment |
Posted: Wed Aug 04, 2021 7:11 pm Post subject: |
Just catching up with this project.
What a lovely pickup you have there, really smart looking.
I’m a big Austin fan, I’ve got two Counties Austins, a Somerset and Hampshire, so a warm welcome to the world of bulbous Austins.
Very impressed with your welding skills too. Some people spend a fortune having welding done, when just picking up a welder and having a go yourself is not only satisfying and cheaper, but you usually get better results too.
(Having seen the quality of the ‘welding’ the previous owner paid for on my Cambridge). It was so bad I’m sure I could do better blindfolded!
I can thoroughly recommend attending the Austin Counties Autumn rally at Tenterden in Kent if you can make it. I’ve moved away so it’s a bit of a trek for me these days, but they always used to get great turnouts.
Regards
Richard |
Miken
Posted: Fri Aug 13, 2021 8:32 pm Post subject: |
Ive been making progress on the cab repair.
Ive replaced most of the windscreen pillar and worked my way down to... whatever this bits called.
Im not clever enough to do proper butt welds so I spot weld the little tabs (that you can see in the pictures) onto one side of the joint which doubles the thickness of the metal and makes it easier to weld. Also helps reduce distortion
Miken
Posted: Fri Aug 13, 2021 8:43 pm Post subject: |
Here is the new section of gutter fitted and the new metal primed
