1937 Morris 8 Series 1 - new addition here at OCC HQ
Goto page Previous  1, 2, 3, 4, 5, 6
PostPosted: Wed Nov 18, 2020 1:13 pm    Post subject: Reply with quote
With regards to gummed piston rings?
A chum[a very experienced large vehicle mechanic---as-was]... got some Wynn's oil additive on an offer, and chucked a can into the sump of his old Series 3 Landy...which ran nicely enough, but burnt oil like no tomorrow.
{this too is a real oil raggy jobby...straight from field to road...almost]
Anyway, his opinion is, what had he to lose?
Apparently, the oil consumption has dropped considerably, and the engine runs even smoother. Tickover would put a field marshal to shame...
Anyway, just a thought...for the price of a costa coffee?
SwallownAmazon
PostPosted: Mon Mar 01, 2021 11:44 pm    Post subject: Reply with quote
One question I have about the plug leads that you made up is do they affect TV reception? It would seem you have no interference suppression with those ends?
I think there was something that could be done about it but I can't remember it now.
Just signed up to this forum as I have a 1937 Morris 8 that I have just got back on the road after sitting for 25 years in my garage. One of the lesser jobs was to suppress the ignition leads with NGK plug caps. Not original I know but needs must....... I also fitted a 5,000 ohm suppressor in the coil HT lead and there in now no interference whatever with the engine running. The thyristor across the fuel pump points also helps in that respect.
My car has several mods to improve comfort:
USHM 3 engine and four-speed gearbox
12v starting with an additional 6v battery
12v power supply to the interior for the radio and USB charging point
LED exterior lights
Flashing indicators in addition to the trafficators
etc...
SwallownAmazon
PostPosted: Mon Mar 01, 2021 11:56 pm    Post subject: Reply with quote
No idea why my post "triple posted! Embarassed
All I did was post and got a PHP error message. I then went to the previous page to see what happened and then went back to the main menu.
Weird. Rolling Eyes
PostPosted: Tue Mar 02, 2021 9:23 am    Post subject: Reply with quote
Weird. Rolling Eyes
Welcome to the forum, yes it does that for some reason on an irregular basis.
Rick (OCC Admin)
PostPosted: Tue Mar 02, 2021 9:26 am    Post subject: Reply with quote
LED exterior lights
etc...
Most ignition cable sold these days is resistive, so can be plumbed in without anything else, if it isn't you can add a resistor as SwallowAmazon has done.
PostPosted: Tue Mar 02, 2021 10:47 am    Post subject: Reply with quote
Is a "suppressor" the same as a "resistor" the same as a thyristor, the same as a transil, the same as a diode, the same as a varistor???
This is why I get confused with electrics.
That and because I am a bit thick.
PostPosted: Tue Mar 02, 2021 12:40 pm    Post subject: Reply with quote
Short answer is no.
The suppressors in car ignition leads are resistors but not all resistors are used as suppressors. All the other devices you list have their own function and they are not just other names for the same device.
1939 SS Jaguar 2 litre saloon
PostPosted: Fri Apr 09, 2021 3:41 pm    Post subject: Reply with quote
Afternoon all,
I've been catching up with a few jobs on the M8 this week. The job list at the moment is to give it another oil change, check compressions, and start having a poke around underneath and also look at the rest of the running gear (brakes etc). It's now up on stands so that this next list of tasks can be attacked.
A bit more about all this now uploaded here:
https://youtu.be/yFNYLfq-Vqw
Rick (OCC Admin)
PostPosted: Thu Apr 15, 2021 8:30 pm    Post subject: Reply with quote
This evening I made a start on stripping down the front brakes, so far it's been coming apart reasonably easily. The front linings don't look too worn but obviously I'll be replacing flexis and attending to the wheel and master cylinders as required. The end of the hydraulic pipe closest to the flexi appears to be copper.
Rick (OCC Admin)
bjacko
PostPosted: Fri Apr 16, 2021 8:27 am    Post subject: Morris 8 Brake system Reply with quote
All the pipes were copper originally. Note that most of the threads are USA
because Lockheed was a US company and even though the parts were made in UK they are mostly US threads. Also be careful not to lose the very thin washers each side of banjo connection etc. While you have them apart get the wheel cylinders and master cylinder sleeved with stainless steel.
Page 6 of 6
