old iron
Posted: Wed Apr 21, 2021 11:02 am Post subject: Engine oil to use |
I have managed to confuse myself, I have decided to use a mono grade oil in my recently rebuilt 1934 Austin engine. But I am unsure which grade to go for. My chosen brand is Comma who supply a SAE 30 but they say it’s for winter use, the SAE 40 grade would be the next choice but the spec’ tell me this is a ‘multi grade ‘. What to do?
Thanks |
Posted: Wed Apr 21, 2021 11:33 am Post subject: |
You are certainly seeking to experience all aspects of vintage motoring.
Peter. _________________ http://www.nostalgiatech.co.uk
old iron
Posted: Wed Apr 21, 2021 11:39 am Post subject: |
I think it’s my age getting to me, been vintage motoring for about twenty odd years, seem to be forgetting more than learning, |
Joined: 14 Oct 2016 Posts: 1953 Location: East Yorkshire
Posted: Wed Apr 21, 2021 2:20 pm Post subject: |
https://www.classic-oils.net/Morris-Golden-Film-SAE-40
Above as an example, but good stuff all the same... _________________ Dellow Mk2, 1951 built, reg 1952.
Miken
Posted: Wed Apr 21, 2021 5:02 pm Post subject: |
You could go to the Comma web page and fill in the "Ask an expert" question form, Or better still, phone them up and ask for tech support. They wil know. |
Joined: 31 Jul 2009 Posts: 1775 Location: Market Warsop, Nottinghamshire
Posted: Thu Apr 22, 2021 8:13 am Post subject: |
I run a straight 40 grade in my Austin Seven all year round, but, yes, it would be usual to use 40 in the summer, and 30 in the winter.
If the oil is described as SAE 40 then it is not a multigrade oil; all multigrade oils are described with their hot and cold ratings, like 20/50, 10/30, or whatever.
With a pre-war engine with non-full-flow filtration, be very careful of using a modern high-detergent oil. If you are starting from scratch with a newly-rebuilt engine, and you know that all the oilways have been thoroughly cleaned out, then fine, but any residual contamination will soon be flushed out and may well clog the filter gauze without you realising it. This was the result of using a modern oil without thought in my Appia; the resulting engine rebuild was very expensive!
_________________ in the garage: 1938 Talbot Ten Airline
old iron
Posted: Fri Apr 23, 2021 2:31 pm Post subject: |
Miken wrote: | You could go to the Comma web page and fill in the "Ask an expert" question form, Or better still, phone them up and ask for tech support. They wil know. |
Yup I did just that and they came back on email very quickly. They advised SAE 40 for summer and SAE 30 for winter. I purchased two gallons of their brand.
Thanks to all contributors. |
