Posted: Mon Jun 09, 2008 8:56 pm Post subject: |
The spare wheel in the SS Jaguar is stored horizontally beneath the boot and requires you to hinge up the compartment door to gain access. However, before you can hinge up the door you need to hinge down the rear bumper.
This is fine when the car is sitting on fully inflated tyres but with a puncture on the rear it isn't possible to hinge the bumper down because it hits the ground and also prevents you from plugging the supplied pillar jack into the
rear jacking points.
As a further bonus design feature the pillar jack has insufficient lift to get the wheels clear of the ground although in fairness to the designer this only afflicts front wheel punctures.
Oh, and I almost forgot to mention the "space saver" spare wheel. The spare wheel compartment has insufficient height to accomodate the tyre width so your spare needs to be stored deflated.
Peter |
Posted: Mon Jun 09, 2008 10:34 pm Post subject: |
Surely when wheel isin its correct straight ahead position and not as in your pic you just poke your arm through the top half of steering wheel
Is it the wiper switch on the left?
Anyway placed centrally there it is clearly to look symetrical and neat - design over functionality a usual
Not sure what went wrong switch the 3 oddly placed switches/warning lights on the right though PO adds:roll:
On my P5 the standard fit electric washers is on the left side of the instrument pod - its clearly labled for the passenger to see but completely out of sight of the driver and MOT inspectors Drivers find it by feel.
The first models did have a non-electric floor pump and they could not find a more convenient place I suppose when the electric pump was fitted in 1962 _________________ Rover P2
Posted: Mon Jun 09, 2008 10:44 pm Post subject: |
Phil - Nottingham wrote: | Surely when wheel isin its correct straight ahead position and not as in your pic you just poke your arm through the top half of steering wheel
yeah of course, but its still a bit of an angle to get through, not a natural move at all
talking of dodgy dash layouts again, was it the Marina that cunningly angled the ICE (read: dodgy wireless) away from the driver towards the passenger?
Posted: Mon Jun 09, 2008 10:47 pm Post subject: |
One thing that anoys me is the horn being on the indicator stalk on the left hand side, so anoying passengers can hoot your horn when you are driving, it really pees me off.
One guy the other day hit my steering wheel trying to do the horn, I said don't do that too hard, you are hitting my air bag!
Supose this is more a rant over passengers, but there we go! |
Posted: Mon Jun 09, 2008 11:04 pm Post subject: |
On my classic Range Rover I have to stretch full arms length to adjust the radio _________________ ROVER
One of Britain's Fine Cars |
Posted: Mon Jun 09, 2008 11:48 pm Post subject: |
Horns on stallks are bad but when did you last use the horn? The really retrograde step was moving the dip switch onto a stalk.
Those nice floor dip switches were great. Now you have to keep a hand, that's
busy doing something else, hovering near the stalk while your left foot is doing nothing.
Peter |
Brian M
Posted: Tue Jun 10, 2008 7:43 am Post subject: |
peter scott wrote: | The really retrograde step was moving the dip switch onto a stalk.
Those nice floor dip switches were great. Now you have to keep a hand, that's busy doing something else, hovering near the stalk while your left foot is doing nothing.
Peter |
While reading the first posts on this I was composing my criticism of floor mounted dipswitches, and then came to Peter's support of this particular pet hate.
On the Amazon the dip switch is right where I rest my left foot, so I am always putting full beam on inadvertently. And then, when blatting along a country lane after dark requiring main beam, I always seem to be changing gear when an oncoming car is encountered so I need another left foot to dip the lights.
Give me a dipswitch on a stalk anytime - I usually have a spare finger to dip the lights, the driver in the other car always seems to have a spare or two! _________________ Brian
Posted: Tue Jun 10, 2008 9:59 am Post subject: |
Brian M wrote: |
While reading the first posts on this I was composing my criticism of floor mounted dipswitches, and then came to Peter's support of this particular pet hate. Give me a dipswitch on a stalk anytime |
Excellent! What dull place the world would be if we all agreed on everything.
Peter |
Posted: Tue Jun 10, 2008 1:10 pm Post subject: |
I thought Peter's post was a plug for an automatic! |
Posted: Tue Jun 10, 2008 1:34 pm Post subject: |
PAUL BEAUMONT wrote: | I thought Peter's post was a plug for an automatic! |
Paul, you're just trying to wind me up.
Yes, in addition to dip stick stalks I also hate automatics. Stupid things change down or slip at the slightest provocation even with a powerful torquey engine and of course they can't anticipate the need to change down when you do want more grunt.
Do you get torque converter lock up switches? That would help. Useful for decent standing start acceleration too. Otherwise you're stuck with revving up the engine in neutral then slamming it into gear. A bit brutal.
Peter |
Brian M
Posted: Tue Jun 10, 2008 10:05 pm Post subject: |
peter scott wrote: | in addition to dip stick stalks |
Now I see why you are confused - you have been trying to check your oil level with a stalk on your steering column !! _________________ Brian
Posted: Tue Jun 10, 2008 11:33 pm Post subject: |
Oh no! I could end up with an unfortunate nick name. |
Uncle Joe Guest
Posted: Wed Jun 11, 2008 7:52 am Post subject: |
Well, personally I like both floor mounted dipswitches, and automatics.
The thing that I dont like about cars is the fact that they all seem to have an ignition switch that must be operated by the right hand. Dont Car Designers (or designers in general) realise that there are left handed people in this world? |
Posted: Wed Jun 11, 2008 8:41 am Post subject: |
UJ you should try a Stag, ignition key on the LHS, gets me every time as I try and put the key into the light switch |
