Posted: Sun Oct 12, 2008 10:10 am Post subject: |
Engine reminded me of my old 1935 DX Vauxhall with those side covers...
thinking about it, they were probably closely related. _________________ If you tie a piece of buttered toast to a cat's back, then drop it off a high building. It will hover just above the ground rotating slowly. |
Joined: 23 Nov 2007 Posts: 3606 Location: South Cheshire
Posted: Sun Oct 12, 2008 10:19 am Post subject: |
Make sure you blow all the oilways out with compressed air when you are done cleaning it, especially the one's in the crank , its amazing what gets in them once you clean things up!  |
Posted: Sun Oct 12, 2008 10:55 am Post subject: |
Jim Walker wrote: | An internal phenomenon in a rotating bearing called an "oil wedge" keeps the bearing surfaces apart.
Jim. |
Yes, it's interesting how bearings are lubricated. I used to think that you needed oil pressure to cushion the impacts on big ends but apparently the forces present are much greater than those generated by any oil pump and it is this dragging of oil into the wedge that counter acts the combustion pressures and prevents metal to metal contact.
