My 1957 A35 "Black Pig"
PostPosted: Mon Nov 23, 2009 2:08 pm    Post subject: Reply with quote
looking better all the time - what do you want for the rad muff? (PM me if you prefer)
[edit - I might have some mirror arm extensions, can you take a close photo showing how the mirror head fits]
Rick (OCC Admin)
PostPosted: Mon Nov 23, 2009 4:25 pm    Post subject: Reply with quote
Thanks Rick, PM sent.
Here are the mirror stems:
The stems are approx. 4" long.
1935 Standard Twelve
1953 Austin A40 Somerset
1958 Austin A55 Cambridge
1959 Austin A35
1980 Vauxhall Royale 2.8 auto
1987 Austin Maestro 1.3 L
PostPosted: Mon Nov 23, 2009 6:09 pm    Post subject: Reply with quote
Standard Desmo Boomerangs - the mirror head which come in 3 oblong sizes and a round one has a course threaded capitivated loose stud with a flat on it to match the, in effect, D shaped hole in the stem.
Tex or Magnatex mirror heads will also fit reasonably well if the Desmo nut is used
Rover P2
Morris Mini Traveller Mk2
PostPosted: Sat Nov 28, 2009 4:16 pm    Post subject: Reply with quote
I found this and thought you might be interested in it.
Not for the faint hearted
ROVER
One of Britain's Fine Cars
PostPosted: Sat Nov 28, 2009 5:04 pm    Post subject: Reply with quote
Saw it at Hoghton Tower show about 3yrs ago, looks as if he has done a bit more to it.
The wheel is altered and I don't seem to remember the spider web.
PostPosted: Sat Nov 28, 2009 5:52 pm    Post subject: Reply with quote
Looks like a Mk2 A40 dash in there, overall a bit of an acquired taste Confused
Rick (OCC Admin)
Keef
PostPosted: Sat Nov 28, 2009 5:55 pm    Post subject: Reply with quote
Yep, an early pre-imitation-wood one. Smile
Also has A40 seats.
Keef - Sheerness Kent UK
PostPosted: Sat Nov 28, 2009 6:11 pm    Post subject: Reply with quote
might give Rich H some ideas for his!!?? I'm already designing a gothic look for my van
Wink
Rick (OCC Admin)
clascar
PostPosted: Sat Nov 28, 2009 9:08 pm    Post subject: Reply with quote
It might be worth changing the oil in your gearbox, I did my Rapier and the difference was incredible. make sure you put the correct oil in.
When I exhibit a car I get the Shudders. People queue up to tell me.
You should have done that, you should have done this. Ray
PostPosted: Sun Nov 29, 2009 7:27 pm    Post subject: Reply with quote
Penman - 'Austintatious' was featured in the OC magazine a couple of years ago. Not to my taste, but I can certainly appreciate the work that has gone into it. I particularly like the flying A shaped indicators at the front Cool
Rick - Certainly not!! Wink
Ray - I have been told that the most likely cause of the non-existant synchro on 3rd and 4th gears is broken/rusted synchro springs, which are prone to breaking when the car is parked up for a long time. At some point I will definately replace the 'box, at the moment I'm just double-declutching it.
Spent the afternoon straightening out the original grille as it is cheaper than getting a new one, it's a slow process as the metal was pretty deformed in an accident many years ago Sad I still need a grille badge though.
Last week I had a lot of trouble with misfiring, so on Friday I changed the points, plugs, rotor arm, condenser, distributor cap and also a better 2nd hand distributor as the one that was on it had play in the rotor shaft. Everything seemed fine until returning home last night, it started misfiring and cut out in a layby about two miles from home. I dismantled the carb and blew through the jets to get me home, then this morning it cut out at a busy roundabout Embarassed so had to do the same thing. There wasn't a huge amount of dirt in there, but it looks like the recently fitted filter has failed Sad I should change the petrol tank, but don't really want the car off the road.
1959 Austin A35
PostPosted: Mon Jan 11, 2010 1:09 pm    Post subject: Reply with quote
Some recent pics:
And on a slightly less-snowy day Smile
The car has been totally reliable recently, starting first time every time no matter how damp, and trudging through the snow no problem. The only recent problem I've had is that one of the dynamo brush springs snapped and the dynamo stopped charging, which resulted in a nail biting drive home from Pitsea, at night, using sidelights right up until the last moment Shocked
All fixed now though Smile
1959 Austin A35
Keef
PostPosted: Mon Jan 11, 2010 1:26 pm    Post subject: Reply with quote
They are good little motors. Smile
Some nice pics there as well.
PostPosted: Fri Mar 05, 2010 8:41 pm    Post subject: Reply with quote
I haven't updated this for a while. Touch wood, the A35 is running brilliantly, I used it all through the winter and had no problems with it, apart from leaving it parked outside one night with no antifreeze in it Shocked Went to start it in the morning and a core plug had popped. I was able to change it and luckily the engine escaped damage. A lesson learnt I think.
Recently I heard that lee1984 from this forum was breaking an A35 for spares. He doesn't live far away, so I went over for a look and was able to get loads of parts I'd been after for ages, including front and rear bumpers with overriders, front grille with badge and chrome surround (horseshoe) rear reflectors and flying A and base. Spent most of today fitting the parts:
Before: Bumper twisted and bent from an accident and from a tow rope, I spent some time straightening out and painting the original grille a few months back but never got it good enough.
Before: Twisted front valence.
After: Straightened out with molegrips, not perfect but an awful lot better.
Rear bumper fitted, and new reflectors replacing the damaged and missing originals, I was able to change the rubbers for better ones as well. Sorry about the picture quality.
New Flying A fitted, attatched to a very good base I already had, unfortunately it was a pain to fit due to the bonnet catch being twisted out of shape - I can only assume something went over the bonnet in the accident Shocked
And the finished result. (I know the car needs a wash!) I removed the numberplate (original Hills plate) and polished up the aluminium digits and border - they came up a treat Very Happy
Another recent job we did was change the gearbox. Early last year I spotted a late Minor gearbox on Ebay, 50p start, condition unknown. It was in Southend, and I ended up winning it for 50p! When we came to collect the man said forget about the 50p Razz
Anyway a couple of weeks ago we decided to fit the "ribbed" case 'box, together with a 1098 clutch and flywheel. The original clutch was slipping badly by this point, and turned out to be down to its rivets Rolling Eyes The car is now completely transformed though, the gearbox turned out to be in excellent condition, and coupled with a new clutch make it lovely to drive Very Happy
Jobs to do in the near future include: Change the rear hub seals as they are leaking, and change the rear brake shoes. A couple of areas of welding have to be done before the MOT (May), at the rear of the N/S sill and in the boot floor. Oh and check and top up the front shock absorbers.
If all goes to plan, she should be at the Austin/Morris day at Brooklands on Sunday Very Happy
1959 Austin A35
andycars
PostPosted: Sat Mar 06, 2010 1:11 pm    Post subject: Reply with quote
What a transformation! It's nice to see a car like that still being used as Austin intended. A real stroke of luck with the gearbox too; when your replacement is of unknown condition it's a lot of hassle to fit only to find it's no good (happened with my palm green A35 once). Glad that didn't happen to you.
Andrew
Keef
PostPosted: Sat Mar 06, 2010 1:46 pm    Post subject: Reply with quote
Nice work Richard!
Makes it look even smarter than before; and it wasn't bad before. Smile
Page 3 of 7
