Anyone recognise this wheel??
PostPosted: Tue Nov 23, 2010 9:11 am    Post subject: Anyone recognise this wheel?? Reply with quote
Someone contacted me as he needs to find a replacement wheel to match this one:
"I need some help please.
The pic below shows one of a pair of wheels fitted to what look like
a 1 on off boat trailer build.
The brake drum and bearing housing is a single machined casting
typical of Ford/Volvo items from the 1950s/early 1960s. The brake
back plate is that typical of a rear axle fitting with an aperture
for a cable/handbrake actuator.
The state of the wheel is such that the original markings are no
longer visible without blasting back and then perhaps doubtful.
I have looked and looked on the web without success - plenty of 8
hole wheels but no 9 holers.
Please, if you or any of your associates can help identify what this
is from then it would be very much appreciated as 1 of the rims ought
to be replaced."
Does anyone recognise it? I did wonder about BMC 1100 or 1300, are they on 13" rims??
ajlelectronics
PostPosted: Tue Nov 23, 2010 11:20 am    Post subject: Reply with quote
Looks vaguely like Reliant Regal, but not sure about the offset.
What is the PCD and offset?
PostPosted: Tue Nov 23, 2010 6:42 pm    Post subject: Reply with quote
Pretty sure 1100/1300 wheels are 13". Keef will know if it's ADO 16 Smile
john-saab
PostPosted: Tue Nov 23, 2010 7:07 pm    Post subject: Reply with quote
It looks like a standard MKII Ford escort wheel to me..but i'm often wrong.
Rust Junky & oil addict.
exbmc
PostPosted: Tue Nov 23, 2010 8:34 pm    Post subject: wheel Reply with quote
Looks to me like a wheel from a Morris 1100 Mk2. The early models did not have the holes.
52classic
PostPosted: Wed Nov 24, 2010 6:00 pm    Post subject: Reply with quote
Surely ADO16 had 12" wheels didn't it.
If those are 13" then my guess would be Marina.
PostPosted: Wed Nov 24, 2010 8:01 pm    Post subject: Reply with quote
Come to think of it they do look identical to the ones on my Maestro (13")
PostPosted: Wed Nov 24, 2010 8:32 pm    Post subject: Reply with quote
Austin/ Morris 1300 I'm almost sure
Mother had one and I am sure they were like that.
Also googling 'Austin morris 1300 wheels' look the same and are 9 hole rims with bulging wheel trims.
And as Richard says, were are you Keef
Roger
PostPosted: Wed Nov 24, 2010 8:44 pm    Post subject: Reply with quote
Roger
I'll drop him an email, he obviously hasn't seen this thread yet.
PostPosted: Wed Nov 24, 2010 8:46 pm    Post subject: Reply with quote
Close match
http://www.area51b.freeserve.co.uk/mg/mg1300.htm
PostPosted: Wed Nov 24, 2010 8:51 pm    Post subject: Reply with quote
Allegros definitely had 13" wheels, looking at some pictures again they look the same.
Keef
PostPosted: Wed Nov 24, 2010 8:53 pm    Post subject: Re: Anyone recognise this wheel?? Reply with quote
No. ADO16 are 12".
Keef - Sheerness Kent UK
PostPosted: Wed Nov 24, 2010 8:57 pm    Post subject: Reply with quote
Oh poops
Start again Crying or Very sad
Keef
PostPosted: Wed Nov 24, 2010 9:02 pm    Post subject: Reply with quote
Austin Maxi?
PostPosted: Wed Nov 24, 2010 10:01 pm    Post subject: Reply with quote
Allegro/Maxi then.
