Riley472
Joined: 02 Jan 2013 Posts: 14 Location: Long Eaton Nottingham
Posted: Tue Apr 09, 2013 7:26 pm Post subject: Towbar Electrics Pos Earth |
Sorry if it's a silly question but do I just wire up the towbar as detailed in normal towbar electric diagrams or do you have to change wires around, I am fitting to my Austin Countryman with +Pos earth? Also what about the warning buzzer is this wired the same as a -Neg earth wiring diagram.
Thanks |
Posted: Tue Apr 09, 2013 10:15 pm Post subject: |
Absolutely - as to a warning buzzer it should be dual polarity but if its got any electronics in it it will not work on +ve earth _________________ Rover P2
Riley472
Posted: Sat Apr 13, 2013 5:17 am Post subject: Towbar Electrics Pos Earth |
Thanks Phil |
Riley472
Posted: Mon Apr 15, 2013 3:52 pm Post subject: Towbar Electrics Pos Earth |
Having some right problems sourcing a warning buzzer, suppliers of buzzers I have spoken to have said they will only work on -neg earth.
Does anyone know where I can get a buzzer that will work on +pos earth.
Thanks |
Joined: 23 Nov 2007 Posts: 4763 Location: Swindon, Wilts.
Posted: Mon Apr 15, 2013 4:49 pm Post subject: |
Use the normal indicator warning light instead.
So long as it has a trailer suitable flasher unit, the indicator warning will flash faster when any indicator bulb fails, in the same way that it will on any car when driven solo. _________________ Bristols should always come in pairs.
