wristpin
Posted: Wed May 15, 2013 3:28 pm Post subject: Cylinder head removal |
New to the forum, spent a life time with things mechanical and oily, the last 30 years owning and running a garden machinery business. Now retired with a 1969 Lambretta and a shed (or two!) full of ancient lawnmowers and cultivators etc awaiting attention.
However this question relates to someone else's problem - a cylinder head that refuses to budge.
Way back when I started learning about engines I worked with a time served guy who taught me the basics of engines and good workshop practice (suppose that these days he would be called a "mentor") It was not uncommon then for cylinder heads to be pigs to remove - the anti -freeze of the day would creep up around the studs and everything would be corroded solid. However this guy had a set of tubular cutters - very thin sleeves with fine teeth on the end - that could be slipped over the stud and turned with a hand brace until they worked their way down to gasket level removing all the crud as they went.
I had never come across such things before seeing his and have never seen any since. I suppose that it's possible that they were home made - may be an apprentice exercise, but I remember them being in a nice wooden case and graded for different sized studs. I would be interested to know if anyone else has recollections of such a tool or even has a set?! Sadly my mentor is no longer with us to ask.
Angus |
Ashley
Posted: Wed May 15, 2013 6:06 pm Post subject: |
You're right Angus, I've even seen pictures of them being used, but Ive never seen any on sale in the UK. I wonder if they are any on American tool sites. |
Posted: Wed May 15, 2013 7:25 pm Post subject: |
"feeding in fine rope into the cylinder bores, then turning the engine over on a handle to encourage the head upwards"
Did that the other week Rick in reverse. I fed some rag into the bore of my chainsaw to lock the engine so I could remove the clutch. Itr worked a treat. |
wristpin
Posted: Wed May 15, 2013 8:19 pm Post subject: |
Ashley wrote: | You're right Angus, I've even seen pictures of them being used, but Ive never seen any on sale in the UK. I wonder if they are any on American tool sites. |
That's interesting as my "mentor" had worked on aircraft engines during WW2 and had a lot of American hand tools such as Blue Point long before they became generally available over here or Snap-on got in on the act. |
wristpin
Posted: Wed May 15, 2013 8:24 pm Post subject: |
colwyn500 wrote: | "feeding in fine rope into the cylinder bores, then turning the engine over on a handle to encourage the head upwards"
Yes that's an old chainsaw trick in the absence of the "correct" piston stop. Have also heard of an adaptor being made for the spark plug hole with a grease nipple in it and the cylinder being pumped full of grease to hydraulic it off! |
wristpin
Posted: Wed May 15, 2013 8:26 pm Post subject: |
Rick wrote: | Welcome to the forum Angus.
I can't help with sourcing cutters, but I have read of people in ye olden days feeding in fine rope into the cylinder bores, then turning the engine over on a handle to encourage the head upwards.
What car is it on?
RJ |
Lanchester, at present running quite happily with the head nuts slackened off! |
Posted: Thu May 16, 2013 12:32 pm Post subject: |
If there is enough length protruding you might be able to lock a couple of nuts on the studs and unscrew them from the block.
Ashley
Posted: Thu May 16, 2013 1:43 pm Post subject: |
If you can get new studs and nuts, you can always weld the present ones on and screw out the studs. |
wristpin
Posted: Thu May 16, 2013 2:39 pm Post subject: Head removal |
Thanks for the two suggestions ref removing the studs. Have applied as much force as seems safe in that direction and only a couple have shown any sign of movement. Making some enqiries across the pond re tubular cutters. Fortuneately there is no time pressure on the job so we can afford to sit back and think about it.
Totally different subject - how does one enable the spelling checker on this forum? |
Posted: Thu May 16, 2013 4:38 pm Post subject: Re: Head removal |
wristpin wrote: | Thanks for the two suggestions ref removing the studs. Have applied as much force as seems safe in that direction and only a couple have shown any sign of movement. Making some enqiries across the pond re tubular cutters. Fortuneately there is no time pressure on the job so we can afford to sit back and think about it.
I'm not sire that there iz one
Inglewood
Joined: 28 Dec 2010 Posts: 183 Location: Stone, Staffordshire
Posted: Thu May 16, 2013 5:09 pm Post subject: Re: Head removal |
wristpin wrote: | Thanks for the two suggestions ref removing the studs. Have applied as much force as seems safe in that direction and only a couple have shown any sign of movement. Making some enqiries across the pond re tubular cutters. Fortunately there is no time pressure on the job so we can afford to sit back and think about it.
Spell checker is automatic if you use Chrome browser, perhaps with some others also. I do not think IE has a spell check function. |
wristpin
Posted: Thu May 16, 2013 6:15 pm Post subject: Re: Head removal |
Inglewood wrote: | wristpin wrote: | Thanks for the two suggestions ref removing the studs. Have applied as much force as seems safe in that direction and only a couple have shown any sign of movement. Making some enqiries across the pond re tubular cutters. Fortunately there is no time pressure on the job so we can afford to sit back and think about it.
Thanks, I usually use Firefox - Ah it has objected to Firefox and offered firebox - better find a steam related forum! |
Posted: Thu May 16, 2013 9:30 pm Post subject: |
Spellchecker?
I've been using this one for a few years now.
http://www.iespell.com/
Sits on the command bar and works with 99.9% of websites and programs |
wristpin
Posted: Thu May 16, 2013 11:31 pm Post subject: |
Roger-hatchy wrote: | Spellchecker?
Thanks, will store that for future use as it appears that my Firefox one was working, my spelling must have been better than I thought ! |
