Timstopp
Posted: Sun Apr 20, 2014 2:53 pm Post subject: Morris 8 tourer nearly ready for drive it day.... |
Pictures below start with car back in November when it was in a shipping container. I have been busy and it is now up and running (four speed conversion is great!) but requires some fettling - front drivers side spring needs retempering, unless anyone has a spare for sale?
Front sidelights are sidelights and indicators combined (led)
_________________ North Essex,UK - Morris 8 tourer 1936 - Jaguar x350 |
Rosco663
Posted: Sun Apr 20, 2014 11:26 pm Post subject: Job well done |
Gidday Tim,
Let me be the first to write and congratulations on a job well done
You have been very busy indeed. The car looks fantastic and should give you many years of pleasure.
Do you have any details on the combination led conversion to the Lucas sidelights?
Timstopp
Posted: Mon Apr 21, 2014 10:06 am Post subject: |
Thank you very much gentlemen, not quite original - but I am happy.
The sidelights were converted using a ba15d dual side/indicator bulb and socket from here.
http://www.dynamoregulatorconversions.com/combined-side-and-indicator-bulbs-shop.php
Very simple to do, I used a dremel to remove the old socket (single pin) and araldited (epoxy glue) the dual one on. Fit bulb, adjust white brightness by covering up front white led and job done. I did not need led flasher relays as the resistance from the rear conventional indicators is sufficient to operate the standard flasher. _________________ North Essex,UK - Morris 8 tourer 1936 - Jaguar x350 |
Bob T
Joined: 16 Nov 2010 Posts: 128 Location: Sudbury, Suffolk
Posted: Mon Apr 21, 2014 9:22 pm Post subject: |
Hi Tim,
I may be able to help with the spring I have some spares. I will have a look tomorrow, but you will have to come to Cornard to have a look. If you want to send me your tel no I can give you a ring when I have sorted out what I have.
Best to use my mail, bobtaylor11@hotmail.com
Bob |
Bob T
Posted: Mon Apr 21, 2014 9:23 pm Post subject: |
Hi Tim,
Bob |
Rosco663
Posted: Tue Apr 22, 2014 1:26 am Post subject: |
Timstopp wrote: | Thank you very much gentlemen, not quite original - but I am happy.
Very simple to do, I used a dremel to remove the old socket (single pin) and araldited (epoxy glue) the dual one on. Fit bulb, adjust white brightness by covering up front white led and job done. I did not need led flasher relays as the resistance from the rear conventional indicators is sufficient to operate the standard flasher. |
Thanks very much for the information Tim
The 'King of The Road' sidelights are great looking little units and with this performance enhancement will be great a modification on my Morrie. It will also comply with Australian rules. Also good to show other traffic which way you're heading......
