MattF
Joined: 29 Mar 2013 Posts: 86 Location: Christchurch, NewZealand
Posted: Tue Jul 08, 2014 9:39 am Post subject: Exhaust manifold/exhaust joint on eight S1 |
CRC Maniseal, been told its good stuff but now I've used it on my exaust manifold/exaust joint I'm scaird to start the car up strate away as I dont want to just wreck the seal, but the TDS says to run on idle for 10mins to help cure...anyone had success with not heating it strate away??
Any help PLEASE!! |
ka
Posted: Wed Jul 09, 2014 7:31 am Post subject: |
I use Gum-Gum exhaust paste, by the time the manifold and system is reassembled, the paste is all but dry. _________________ KA
Better three than four. |
D4B
Posted: Wed Jul 09, 2014 8:38 am Post subject: Re: Exhaust manifold/exhaust joint on eight S1 |
MattF wrote: | the TDS says to run on idle for 10mins to help cure.. |
If that's what the instructions say then I would do that.... |
Posted: Wed Jul 09, 2014 9:43 am Post subject: |
Maniseal is a great product. Apply, bolt the flanges together firmly, start the engine, allow to idle and the maniseal will cure beautifully and maintain its seal.
I have used it for years. Many years ago, I drove a truck, and could not get time to spare to have a new exhaust pipe fitted for quite some time. I made many temporary repairs by opening up jam tins, coating with Maniseal on the inside, then clamping over the hole with worm drive hose clamps. Eventually had a new pipe fitted, and found the jam tins in quite good order after taking the old pipe off. _________________ Dane- roverdriver but not a Viking. |
