Rollsroyce engine data
Bernie wade
PostPosted: Fri Jul 11, 2014 7:49 am    Post subject: Rollsroyce engine data Reply with quote
Has anyone got torque tightening data for a RollsRoyce B60 20A engine
Fitted to an early fire engine
Head bolts
Big end bolts
Tappet settings
Firing order
Thanks
Bernie Wade
PostPosted: Fri Jul 11, 2014 12:07 pm    Post subject: Reply with quote
Hi Bernie,
I have the service manual for the Wraith, Dawn, Phantom IV and MkVI Bentley and I can't find any reference to tightening torques for any of the places you list. (Only the slipping load of the vibration damper.)
Probably best to take a guess from the stud material properties.
Bernie wade
PostPosted: Fri Jul 11, 2014 12:17 pm    Post subject: RollsRoyce Reply with quote
Many thanks for your reply
PostPosted: Fri Jul 11, 2014 1:28 pm    Post subject: Reply with quote
Sorry, forgot the firing order.
My Service Manual quotes:
6 cyl
1,4,2,6,3,5
8 cyl
1,6,2,5,8,3,7,4
I see Ashley of this forum gives pdfs of the MkVI manual in his website (although the manual and parts list titles appear interchanged)
http://www.kda132.com/pdfs/partslist/6_E_Engine.pdf
PostPosted: Fri Jul 11, 2014 8:20 pm    Post subject: Reply with quote
Perhaps a BMC site for the Princess R which had the 4 Litre FB60 engine may give some guidance?
Rover P2
Morris Mini Traveller Mk2
Ashley
PostPosted: Thu Jul 17, 2014 5:27 pm    Post subject: Reply with quote
Rolls-Royce never gave torque figures for their engines, instead the specified the length of Tommy bar to be used with a box spanner.
There are two sizes of head bolt, mine are 3/8" and I tighten them to 35lbs/feet. Then because I've had trouble with pattern head gaskets, I do 100 gentle miles and then torque them again and again at 500. If they still go down a lot I keep checking until they settle. Do it with a hot engine because you have an iron head.
Big ends a bit less then I go further until I can get split pins in. Make sure they're a tight fit or they vibrate and fall to bits.
Main bearing too, are happy at 35-40lbs/ft.
Exhaust tappets are 6 thou and inlet 12.
