peppiB
Posted: Fri Jul 24, 2015 8:25 am Post subject: |
Richard,
It was the major fastenings supplier not far from my home who quoted me as the stuff being available only in 10m lots. They are usually quite good, and inexpensive, but this time I had them stumped as they don't stock the M3 rod - other sizes yes, M3 no |
Posted: Fri Jul 24, 2015 9:55 am Post subject: |
Metric threads seem to be like the old woodscrew gauges - all are available, but the odd numbers aren't commonly used. Look at anywhere that shifts large volumes of threaed parts, they tend to go M6-M8-M10-M12 etc in their catalogues. Perhaps it's because those most common threads are roughly equivalent to the old fractional sizes that many of us still think in? |
peppiB
Posted: Fri Jul 24, 2015 4:57 pm Post subject: |
Rod didn't arrive so the old grey matter started turning. Clutching at straws, so to speak, I cut the broken bolt on the unthreaded bit. Then taking a couple of inches of a narrow straw (roughly the same diameter as the bolt) I filled it with Araldite and pushed the 2 halves of the bolt in, leaving half a centimetre gap between the pieces (the length of broken thread that was lost.) Fifteen minutes later and I had a solid bolt. Result. Motor reassembled but not tried yet as I am too knackered to lift the batteries back on |
goneps
Posted: Sat Jul 25, 2015 12:39 am Post subject: |
Bitumen Boy wrote: | Metric threads seem to be like the old woodscrew gauges - all are available, but the odd numbers aren't commonly used. Look at anywhere that shifts large volumes of threaded parts, they tend to go M6-M8-M10-M12 etc in their catalogues. Perhaps it's because those most common threads are roughly equivalent to the old fractional sizes that many of us still think in? |
M3 and M5 are considered common sizes. On the Imperial equivalent theory, 3mm is close to 1/8" and 5mm to 3/16". M7 x 1mm is somewhat scarcer, even though common on French and Italian vehicles.
That said, I'd certainly agree that odd-number BA threads are scarce.
Richard |
