Spin off oil filter conversions.
Ellis
PostPosted: Fri Aug 14, 2015 10:48 pm    Post subject: Spin off oil filter conversions. Reply with quote
My nephew has just had the 2286cc diesel engine changed in his 1965 Land Rover Series 2a and it was only because I had a spare paper type original oil filter that a wait for a specially ordered filter was avoided.
This set me thinking, is there any advantage or disadvantage in converting any classic car to a spin off oil filter conversion? There are conversions for old Land Rover engines as indeed there is one for a Jaguar Mark 2 such as mine which uses a Mann oil filter.
Your opinions please.
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
PostPosted: Sat Aug 15, 2015 5:42 am    Post subject: Reply with quote
I converted my MGA to a spin off filter, mainly for the ease of changing, but also the spin of units to to cost less and are less prone to leaking.
PostPosted: Sat Aug 15, 2015 6:19 am    Post subject: Reply with quote
On wifes Mk2 Mini I put the later Mini (A series) spin on filter head for the same reason - it just bolted on.
Standard LR filters are dead easy to change however as there is plenty of room and the filters are cheap and easy get. Cannot see any point converting at all. Conversion blocks can also leak too.
On our P4 and P5 they are easy (and cheap filters) to change on the bench after just unbolting the 2 bolts on the filter head to the block. Easy to pick out the old rubber seal and fit the new one. It is easy then to fill the cannister with fresh oil to avoid oil starvation and bearing rattle on start up
Rover P2
Morris Mini Traveller Mk2
ka
PostPosted: Sat Aug 15, 2015 6:30 am    Post subject: Reply with quote
I fitted an oil filter to the 10Hp engine, and chose the later Mini spin-off filter set up. Works fine, but anything other than the standard gauze filter has got to be better.
Some motorcycles have a spin-off filter set up. My Commando has just such a filter arrangement, all standard, but using a comparable 2CV filter. This is a free standing mounting, with the hoses clipped on, not idea for a high pressure set up, but works well on the bike.
KA
Better three than four.
PostPosted: Sat Aug 15, 2015 6:37 am    Post subject: Reply with quote
Our Rover 16 P2 has not even got an external filter although a bypass type was available as fitted on the top of range 20HP Sports saloon
Rover P2
PostPosted: Sat Aug 15, 2015 9:48 am    Post subject: Reply with quote
My singer has a spin off filter that uses a ford pinto filter.
Great modification in my eyes
Kev
Ashley
PostPosted: Sat Aug 15, 2015 12:22 pm    Post subject: Reply with quote
I've fitted them to two Bentleys, a Bristol 400, a TR3A, my Healey 3000 and my son fits them to any customer's car that has an older type filter. They're bulletproof, cheap and easier to fit correctly.
PostPosted: Sat Aug 15, 2015 4:50 pm    Post subject: Reply with quote
The old canister-type filters, as fitted to cars such as the A40 Devon and Somerset, aren't all that easy to find, and usually cost a bit when they do turn up. A conversion makes a lot of sense in this instance I think.
