Paul fairall
Posted: Fri Apr 21, 2017 5:22 pm Post subject: The old girl spluttered,popped and banged and died today |
Took the popular out for a run today and visited a restorer, another story.
On the way back it started to misfire, then backfired a bit when I discovered the accelerator pedal went much further down than I realised. I've been struggling up hills thinking its gutless when the pedal was hitting the wheel arch. Eventually it stopped on a hill on a busy road so the AA recovered the car home as it was unsafe to work on it where it was. I was happy to investigate the problem myself once home. While I waited for the AA and the car had cooled down, I tried to start it with choke and it fired but then died. Then just turned without firing. Having no tools, big mistake, I could only remove the distributor cap and check the points had a gap. I suspected the inline fuel filter was blocked, but once home I removed the fuel pipe from the carb and pumped it up manually and it was ok. So I gave it a go and it started, running a bit rough with the choke on but usually is runs fine. Any thoughts welcome
Tomorrow I will take the plugs out and check them. _________________ 1957 ford popular |
Posted: Fri Apr 21, 2017 5:56 pm Post subject: |
How often do you use the car Paul?
I'm sure it's going to turn out to be something simple, but recently, I also had to use the AA in similar circumstances. My little Fiat 500 had not exactly been struggling up hills but I was having to change down more often. My car also had problems starting from cold. It turned out to be valve-seat recession and it had got so bad that one of the inserts had fallen out and jammed the valve open.
So although I doubt you have that exact sort of problem,I would put valves...seating or clearances on the list of suspects. |
Joined: 14 Oct 2016 Posts: 1955 Location: East Yorkshire
Posted: Fri Apr 21, 2017 6:51 pm Post subject: |
Hi..if you are a member of the FSOC, go on their website, members' area, and have a gawk through the back issues of the club magazine?
I think the major suspect is fuel vaporization..?
Are you on the [original] mechanical fuel pump?
Might be worth trying to re-route the fuel line in the engine bay, away from major heat sources?
Some have been known to lag the fuel pipe with ally foil?
Definitely symptoms of vapourisation, however..a Ford sidevalve plague....especially with modern petrol.
One way to overcome the issue is to fit an electric fuel pump, and bypass [remove & blank off] the mechanical pump....[blanking plates are even available from usual sources] |
Paul fairall
Posted: Fri Apr 21, 2017 9:17 pm Post subject: |
My first thought was fuel vapourisation but after it cooled it still didn't start. When I removed the fuel pipe from the carb it took a lot pumps before fuel came out of the pipe, that's got me thinking that maybe the inline fuel filter is at fault. Usually four or five pumps and I can hear the fuel is there. A new filter can't be such a bad thing anyway.
Although I looked at the points gap I had no way of checking it's correct. I will check that tomorrow. When I bought the car I drove it home in pouring rain with the vacuum pipe disconnected and the wiper not working but the engine ran ok.
Since buying the car I've driven it a handful of times but this was probably the furthest I've driven it, but only a little further than another time and nowhere near as far as when I first drove it home. _________________ 1957 ford popular |
Joined: 23 Nov 2007 Posts: 4764 Location: Swindon, Wilts.
Posted: Fri Apr 21, 2017 9:58 pm Post subject: |
Is the breather hole in the fuel cap blocked? _________________ Bristols should always come in pairs.
Paul fairall
Posted: Sat Apr 22, 2017 10:11 am Post subject: |
I picked up an inline filter this morning and if it stops raining I will fit and see if that fixes it. If not I will check the things you have all suggested. _________________ 1957 ford popular |
billysugga
Posted: Sat Apr 22, 2017 1:10 pm Post subject: |
Sometime coils can be more temperamental when hot. Are you getting a good spark. A strobe can help. _________________ Volvo Sugga ,Volvo Trygge
I just wish one was working! |
Paul fairall
Posted: Sat Apr 22, 2017 3:59 pm Post subject: |
Fitted a new fuel filter and it seemed to run much smoother, drove it to the garage about a mile away and about half way there it started misfiring and I only just made it. But I couldn't back it up the slope. I started pushing it with wood blocks in front of the front wheels, pulling the handbrake and then moving the blocks. I reached a crack in the concrete with grass growing out of it and it was too slippery to push any further. So I turned the front wheel and kicking the block up behind the wheel until I got a step in the concrete in the door opening. I just couldn't push or pull it over the step. I then thought about John mills in Ice cold in Alex, I used the starting handle with it in reverse and wound it over the step into the garage. I'm now having a beer, worth waiting for.
When I recover from the effort I will carry out some checks from your suggestions _________________ 1957 ford popular
Paul fairall
Posted: Sat Apr 22, 2017 4:00 pm Post subject: |
The way it misfires and backfires makes me think it's electrical and not fuel. _________________ 1957 ford popular |
alanb
Posted: Sat Apr 22, 2017 5:52 pm Post subject: |
I suggest you check the insulation around the condenser, make sure all connections are good if so then I would suggest trying another condenser. _________________ old tourer
Morris 8 two seater |
Posted: Sat Apr 22, 2017 6:06 pm Post subject: |
A problem I have suffered concerns the distributor.
If there is a bit of crankcase pressure [when hot] I have suffered having oil mist being blown up past the distributor shaft, leading to oil droplets forming on the points.
This can be seen when examining the distributor cap after the misbehavior....cleaning the cap is temporary, as it soon mists up again.
Crankcase pressure always occurs to a greater or lesser degree....and with the 10hp, it finds it difficult to dissipate that pressure...despite having a large-ish oil filler orifice.
My cure has been to switch to one of the Hall-effect conversions which replaces the actual points. I don't have much faith in magic boxes, however. |
petelang
Posted: Sat Apr 22, 2017 7:47 pm Post subject: |
CONDENSER!
Ben there, had that. Spent a fortune on new plugs, coil, leads, points......
All along it was the condenser. Cheap Chinese made junk.
Peter |
