Joined: 25 May 2011 Posts: 2474 Location: South Cheshire
Posted: Thu May 18, 2017 6:52 pm Post subject: |
Miken wrote: | Degreased a high tensile bolt and wound it in by hand with some Loctite 270 threadlocker which the manufacturer produce for "the securing AND sealing of bolts , nuts and studs". |
I think that's the stuff I've got, and never got around to doing the same experiment you did.
The stuff I should have got (and subsequently did get for my rebuild) is Loctite 243 Lock-n-seal, which says "medium strength easily undone with normal hand tools".
That's what I was talking about above - there are many different types of Loctite. |
Joined: 23 Nov 2007 Posts: 4106 Location: South Cheshire
Posted: Fri May 19, 2017 7:44 am Post subject: |
Head studs stretch slightly every time they are tightened up, which weakens them, so unless you are aware of the studs history it's best to replace them. Modern materials are much improved thus reduce the chance of shearing.
Dace |
Posted: Fri May 19, 2017 8:17 am Post subject: |
I have just had to order a new set of head studs due mainly to corrosion. I was quite surprised how much thinner they had become. I think I might as well fit new nuts as well. |
Posted: Mon May 29, 2017 6:55 pm Post subject: |
[quote="Miken"]
After 8 hours I attempted to dismantle it with a socket spanner.
After fitting a long tube extension I merely succeeded in shearing the bolt off.
WOW! At least you proved the stuff works! There will be applications where that is very useful. But its use on studs in this application is meant simply to stop water from creeping up the threads. So you wouldn't use the high-strength 270, rather the low-strength 222.
You could even use the thread sealant such as 577.
I've used these products frequently and I haven't ever been unable to remove a fixing; a quick run over with the blowtorch is all it needs. |
Miken
Posted: Tue May 30, 2017 12:18 pm Post subject: |
[quote="colwyn500"] Miken wrote: |
I agree, I'm not quite yet ready to assemble but I think I will use the 577 loctite. I've used it many times on pressurised steam boiler fittings, engine and gearbox drain plugs and compressed air fittings. It always comes apart really easily when required without any application of heat. |
