Jublybug
Posted: Sun Oct 25, 2015 11:41 am Post subject: |
Yes its one big fiberglass shell,like a bubble with a wooden floor layed over struts in the bottom of the shell . Its been quite well made .
Jim |
Jublybug
Posted: Sun Oct 25, 2015 6:39 pm Post subject: |
Yes the van is a full fiberglass shell ,from what I can see the floor boards are sat on beams set into the fiberglass skin ,there's been a lot of mouse activity and id rather pull it all up and clean it right out rather than just replace the rotten strip in the door opening .
Jim |
Jublybug
Posted: Sun Oct 25, 2015 6:40 pm Post subject: |
Thought that post dident send oops |
Jublybug
Posted: Sat Nov 07, 2015 5:31 pm Post subject: |
Well the floor came up today ,the screws wouldent come out so I had to chisel round them and pull the boarding up round them once out Il be able to remove the screws with grips .pulled the old insulation out as well found yet more mouse nests .
Jim
Jublybug
Posted: Sat Nov 14, 2015 7:50 pm Post subject: |
No progress due to work on the soon to be Baja tow car
Jim |
Jublybug
Posted: Tue Dec 08, 2015 8:33 pm Post subject: |
Well that's it got to go this time storage problems again
£500 open to offers tho
Jim |
Jublybug
Posted: Tue Feb 02, 2016 10:05 pm Post subject: |
Its still hanging in there , looks like I might end up finishing the resto ended up moveing other things on so I can keep some of my storage .
Jim |
Jublybug
Posted: Mon Aug 01, 2016 8:40 pm Post subject: |
Some new info has come to light and it seems there where only 6 of these wake fibrelight vans made 5 and a camper van where known and one missing ,which looks like the one ive dug out is the elusive missing van . Cool a new friend of mine is trying to find out more from the family of the chap who had the other vans ( who has sadly past on )
.resto will be moveing on soon I promise .
Jim |
Jublybug
Posted: Sat Jul 08, 2017 8:38 pm Post subject: |
Slow progress at the moment ,I re dug out the van from its new resting spot got it jacked up and on stands with the wheels off ,it looks like the tyres have rubbed on the top of the wheelwell when we dragged it back ,so eather sagged suspension or incorrect size tyres( anyone know what size for a b&b chassis 13" wheels) . I'm going to get the bearings out and cleaned to inspect them and strip and clean all the brake mechs see what's going on with the damper so I can get the van movable . I also need to sort out where the jocky wheel pinch bolt has snapped off and see it i can source a jocky wheel and lower half to fit what ive got left .
Also gave the van a clean so it looks cared for again .
Jim |
Jublybug
Posted: Mon Jul 10, 2017 8:27 pm Post subject: |
Did I little on the van tonight , ended up drilling out the screws holding the A frame cover to get it off . All the metalwork looks ok under there so started to lube and free off the mechanism ,to my amazement the brakes now work ,Il still strip and service them as i go along
Jim |
Jublybug
Posted: Mon Jul 17, 2017 7:38 pm Post subject: |
More done tonight stripped the ns brake cleaned out and regreased the wheel bearing . Its got a slight bit of wear , and so do the shoes ive fully adjusted them but the drum still turns .( anyone got any set up data on B&B brakes ) .
Jim |
Jublybug
Posted: Tue Jul 18, 2017 8:08 pm Post subject: |
Worked on the os brake and bearing tonight , sounds alot better . Looks like the shoes will need replacing.
How much force should it take to press in the tow damper? Mine now will press in reasonably easily and has started to return out now on its own . .
Jim |
christine lowery
Posted: Wed Jul 19, 2017 9:12 am Post subject: |
B&B hitch service information can be found on the Thomson caravan website
the hitch should be quite hard to push back and should only return very slowly // your damper may be shot new ones on ebay |
Jublybug
Posted: Wed Jul 19, 2017 6:49 pm Post subject: |
Cool thanks Il have a look for the info on that site .
Jim |
Jublybug
Posted: Fri Aug 11, 2017 8:06 pm Post subject: |
Checked both shockers on the van tonight ,seem to be firm and still operable. I was surprised how easy it was to remove the bolts after the chassis been buried twice now .
Jim |
