More mystery photos
Goto page Previous  1, 2, 3 ... 101, 102, 103 ... 142, 143, 144  Next
PostPosted: Fri Jan 19, 2018 10:32 am    Post subject: Reply with quote
Quite a toughie that one, who says only modern cars all look the same!?! Smile
Da Tow'd
PostPosted: Mon Jan 22, 2018 4:36 am    Post subject: Reply with quote
what is it?
Kenham
PostPosted: Mon Jan 22, 2018 9:34 am    Post subject: Reply with quote
Marcos ?
Da Tow'd
PostPosted: Mon Jan 22, 2018 6:28 pm    Post subject: Reply with quote
negative kenham
troutrunner
PostPosted: Mon Jan 22, 2018 11:01 pm    Post subject: Reply with quote
I thought Piper but not so sure..........
Paul
1937 Ford Model Y.
1939 Austin 10.
1955 Austin A30.
1958 Ford 300E van.
1961 Austin A40.
1964 Wolseley Hornet.
1965 Series2a Land Rover.
1968 Wolseley Hornet.
1994 Peugeot 405 Est. 2of.
Nil illegitimi Carborundum
Da Tow'd
PostPosted: Tue Jan 23, 2018 12:58 am    Post subject: Reply with quote
Nope
Clue: it was named after a famous race
Kenham
PostPosted: Tue Jan 23, 2018 9:56 am    Post subject: Reply with quote
Grand National ? Very Happy
PostPosted: Tue Jan 23, 2018 12:14 pm    Post subject: Reply with quote
An MGB at Le Mans (or Sebring) or ( Daytona)????
Art
Da Tow'd
PostPosted: Tue Jan 23, 2018 1:55 pm    Post subject: Reply with quote
Close Art
it is a Austin Healey Le Mans Sprite
10 cars Built from 1965 to 1969
1965 12th overall and first in class; the type's best result at Le Mans.
1966 it finished 18th overall and first in class at Sebring
Engine
Configuration BMC XSP Straight 4
Location Front, longitudinally mounted
Displacement 1,293 cc / 78.9 cu in
Bore / Stroke 71.1 mm (2.8 in) / 81.3 mm (3.2 in)
Compression 11.9:1
Valvetrain 2 valves / cylinder, OHV
Fuel feed 2 Weber 45 DCOE Carburettors
Aspiration Naturally Aspirated
Power 105 bhp / 78 KW @ 7,200 rpm
BHP/Liter 81 bhp / liter
Drivetrain
Front suspension double wishbones, coil springs
Rear suspension live axle, semi-elliptic leaf springs
Gearbox MG 4 speed Manual
Drive Rear wheel drive
Dimensions
Weight 610 kilo / 1,345 lbs
Wheelbase / Track (fr/r) 2,030 mm (79.9 in) / 1,070 mm (42.1 in) / 1,070 mm (42.1 in)
Performance figures
Power to weight 0.17 bhp / kg
Top Speed 236 km/h (147 mph)
PostPosted: Wed Jan 24, 2018 11:10 am    Post subject: Reply with quote
Napier came to mind as a possibility ...??
PostPosted: Wed Jan 24, 2018 12:00 pm    Post subject: Reply with quote
I don't think it's a Napier - they usually had the radiator filler on a very tall stack.
My guess would be a Fiat, probably a circa 1908 20-30hp, but that radiator shape is hardly unique; the front axle looks right for a Fiat, though.
PostPosted: Thu Jan 25, 2018 11:58 am    Post subject: Reply with quote
Cheers Mike.
The following two photos were sent over a while back, believed both taken in France in 1946.
PostPosted: Thu Jan 25, 2018 2:13 pm    Post subject: Reply with quote
Could the second one be a Renault Colorale?
https://en.wikipedia.org/wiki/Renault_Colorale
I know the bonnet side is different, but there are some similarities to the
Vivaquatre in the first picture, equally it could be a pre or just post war American car
PostPosted: Thu Jan 25, 2018 2:37 pm    Post subject: Reply with quote
I think it has the look of a French Ford and came up with this. The front grille isnt exactly as pictured but maybe it’s a ‘top of the range’ model. The hubcaps have the typical Ford V8 emblem
https://farm3.static.flickr.com/2126/5742630863_b9a32ebca3_b.jpg
Art
PostPosted: Mon Jan 29, 2018 2:02 pm    Post subject: Reply with quote
Large Morris?
Page 102 of 144
