Popular not running well
billybob
PostPosted: Tue May 08, 2018 8:46 pm    Post subject: Popular not running well Reply with quote
Looking for a bit of help here, recently purchased a 56 103e that wasn’t running and had stood for a while. Good spark, timing set correctly, new su fuel pump. Fresh fuel.
Starts well on choke, engine sounds well but it won’t tick over when choke returned. I have stripped down the carburettor, it has had a rebuild kit fitted at some stage, jets all clear, blown out all passages etc.
I think I need to try another carb.
Any thoughts?
Thanks, Jeff.
PostPosted: Tue May 08, 2018 10:28 pm    Post subject: Reply with quote
carb needs tuning.
Also ensure points & timing set correctly.
Have you joined the FSOC?
Kenham
PostPosted: Tue May 08, 2018 10:38 pm    Post subject: Reply with quote
Manifold gasket sucking air perhaps?
PostPosted: Wed May 09, 2018 7:53 am    Post subject: Reply with quote
On a similar note, make sure there are no air leaks where the pipe for the vacuum wiper connects to the manifold. In fact I'd blank it off temporarily as any leak from the connection, along the pipe to the wiper motor, will cause problems with air being drawn in.
I still wonder about the jets and drillings inside the carb being clear. Have you unscrewed the block that's on the side of the float chamber when you remove it, to check in their for a blockage?
Photo from the Small Ford Spares page, item 9693 is what I'm referring to.
The standard fuel pump is by AC, rather than SU if I remember right.
PostPosted: Wed May 09, 2018 10:56 am    Post subject: Reply with quote
Jeff,
The fact that it starts and runs on choke but not without choke suggests to me an air leak in the intake system. The car has vacuum wipers so if you disconnect the pipe that feeds the wipers and block the inlet for a start and see how that goes. If you have a propane torch, turn on the gas but don’t light it. Waft the gas around the inlet manifold and carb. flange and see if the revs rise. If they do this is where your leak is.
Art
billybob
PostPosted: Wed May 09, 2018 4:59 pm    Post subject: Reply with quote
alastairq wrote:
carb needs tuning.
Hi Alistair, I set the air adjusting screw to 2 1/2 turns out as a base setting.
Timing set using the timing pin and a test lamp on the points.
Points set to 0.015’’
Winding the air screw in and out has little effect, so an air leak looks possible.
Jeff.
billybob
PostPosted: Wed May 09, 2018 5:01 pm    Post subject: Reply with quote
I will check this out. Thanks,
billybob
PostPosted: Wed May 09, 2018 5:10 pm    Post subject: Reply with quote
Thanks, I will have another strip down of the carb at the weekend, yes I removed the emulsion block.
I will block off the vac pipe as well.
It now has a new SU fuel pump as the copy AC pump was useless.
billybob
PostPosted: Wed May 09, 2018 5:13 pm    Post subject: Reply with quote
47Jag wrote:
Jeff,
Art
Hi Art, 45 years of car tinkering and I have not heard of this.
I will definitely give it a try, thanks Jeff.
billybob
PostPosted: Fri May 11, 2018 5:09 pm    Post subject: Reply with quote
Bit of an update,
I have removed the manifolds and found that the two outer bolts were loose / stripped and not doing much. This looks hopeful to the cause of the running problems.
The exhaust manifold is in poor condition and very thin / weak on the outer edge. Now looking for another better used one or perhaps a new reproduction fingers crossed this fixes it.
Jeff.
PostPosted: Fri May 11, 2018 8:40 pm    Post subject: Reply with quote
HAve you joined the Ford Sidevalve Owners Club yet?
Manifolds will be available via the Club stores.
As far as I'm aware, there have been no 'repro' manifolds made.
However, you do have the option of splashing out and buying an Aquaplane exhaust manifold.......
As you may know, this is a tuning option, being a better design than the original stock part.
However, by doing so, it may not be possible to retain the stock inlet manifold.
PostPosted: Fri May 11, 2018 8:49 pm    Post subject: Reply with quote
Jeff,
In a professional garage where acetaline if available that would be the method, but not everyone has a welding kit sitting in the corner, so that’s why I suggested propane. The object of the exercise is to richen the mixture to compensate for the ‘leak’ so if the manifold is leaking it sucks in the more volatile gas and speeds up.
As a matter of interest did you try the gas on the manifold to find the loose bolts?
Art
billybob
PostPosted: Fri May 11, 2018 9:38 pm    Post subject: Reply with quote
47Jag wrote:
Jeff,
Art
Hi Art,
I was planning to at the weekend when I have time to tinker, but the battery is disconnected as I have the ammeter out for repairs and the trafficator wiring to replace. So I cannot run the engine at the moment.
Jeff.
billybob
PostPosted: Fri May 11, 2018 9:48 pm    Post subject: Reply with quote
Hi Alistair,
I have found new manifolds here https://www.smallfordspares.co.uk/products/e93a-9430-a-exhaust-manifold-8hp-and-10hp
They look stronger in the outer two hot spot bolt areas (thicker).
Jeff.
PostPosted: Sat May 12, 2018 8:51 am    Post subject: Reply with quote
I stand corrected there, despite being a regular customer / browser of SFS!
Cannot help thinking, if a member of FSOC [if only for access to a huge spares stores?] then a word to the storekeeper might get a much cheaper, sound original manifold? [Membership fee , for other lurkers, means when ordering spares, no postage costs?]
Also there would be access to the technical expertise in sidevalves that exists....and these guys really know their stuff!
Or, am I ''preaching-to-the-converted?''
