GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Tue Apr 17, 2018 7:39 pm Post subject: |
made a new throttle pedal to operate the twin SU's, used a morris 1000 pedal and added a few more bend's and a skateboard wheel,
_________________ 1957 - 103e - popular, |
Paul fairall
Posted: Wed Apr 25, 2018 8:33 pm Post subject: |
Does all of it fit inside the car and a cable through the bulkhead? _________________ 1957 ford popular |
GARAGE HERMIT
Posted: Thu Apr 26, 2018 12:13 pm Post subject: |
Paul fairall wrote: | Does all of it fit inside the car and a cable through the bulkhead? |
yes,
it was a bit of a faff on but work's a treat,
a few people i've talked to have used early mini pedal's too, _________________ 1957 - 103e - popular, |
Paul fairall
Posted: Thu Apr 26, 2018 7:29 pm Post subject: |
GARAGE HERMIT wrote: | Paul fairall wrote: | Does all of it fit inside the car and a cable through the bulkhead? |
yes,
a few people i've talked to have used early mini pedal's too, |
The wheel is a bit trick dude _________________ 1957 ford popular |
Posted: Fri Apr 27, 2018 12:09 am Post subject: |
Paul fairall wrote: | GARAGE HERMIT wrote: | Paul fairall wrote: | Does all of it fit inside the car and a cable through the bulkhead? |
yes,
The wheel is a bit trick dude |
My first reaction to the photo was "VW!".
Early Beetles had just such a wheel. A common accessory was a flat metal pedal hinged to the floor & resting on the wheel. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
GARAGE HERMIT
Posted: Fri Apr 27, 2018 5:56 pm Post subject: |
thank's,
i'll put a dome nut on the end of the through bolt to tidy it up a bit, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Wed May 09, 2018 6:08 pm Post subject: |
fitted some old style holiday sticker's,
fitted my new old style steering wheel,
mounted one front seat, still have to paint the mount's,
replaced the window seal's, that was a right mess on, still have the other door to do,
mounted the imitation ford 1930's rear light's, still have to blank off the original pop mounting hole's,
bought an old door knod to use as a gear leaver knob, i'll have to stain it to match the steering wheel though,
GARAGE HERMIT
Posted: Sun May 13, 2018 11:55 am Post subject: |
well good new's and bad new's,
good new's is managed to get the SU carb's balanced and running right, they're quite finiky to set up, for me anyway,
bad new's is there's a hairline crack in the engine block (pic) the water isnt running out more of a weep, the clutch is slipping like a goodun, and the steering box is very worn, very nerveracking drive,
so what to do, to sort out these problem's is going to cost a few quid, and quite a bit of work, so i'll have to have a think, bugger,
GARAGE HERMIT
Posted: Mon May 14, 2018 10:24 am Post subject: |
Rick wrote: | Is there any adjustment left in the steering box?
RJ |
no, i've adjusted it, no real improvement, i've been given an address of a s/box refurb firm, so see what they say, _________________ 1957 - 103e - popular, |
alanb
Posted: Mon May 14, 2018 11:17 am Post subject: |
1 and a half inches either side of centre measured at the steering wheel rim is considered acceptable, don't be fooled into comparing it with modern cars or with rack and pinion steering, the best steering box conversion is to use a modified VW box and column as used by the MG boys. _________________ old tourer
Morris 8 two seater |
Posted: Mon May 14, 2018 11:35 am Post subject: |
If there is any end float in the column that can cause lost motion. Look at the top of the column from the side and if your steering wheel moves in or out when you rotate it then that's fixable.
GARAGE HERMIT
Posted: Mon May 14, 2018 8:48 pm Post subject: |
alanb wrote: | 1 and a half inches either side of centre measured at the steering wheel rim is considered acceptable, don't be fooled into comparing it with modern cars or with rack and pinion steering, the best steering box conversion is to use a modified VW box and column as used by the MG boys. |
mine's a bit more than 1 1/2", yes i'm not comparing it with a modern car, i'm not un-nerved by most driving scenario's having ridden a motorcycle for over 45 year's, but this thing is leathal,
the VW box mod sound's interesting, do you have any more information on it please, _________________ 1957 - 103e - popular, |
GARAGE HERMIT
Posted: Mon May 14, 2018 8:49 pm Post subject: |
peter scott wrote: | If there is any end float in the column that can cause lost motion. Look at the top of the column from the side and if your steering wheel moves in or out when you rotate it then that's fixable.
Peter |
no end float, i adjusted the cup & cone ball race, not too tight not too loose, _________________ 1957 - 103e - popular, |
alanb
Posted: Mon May 14, 2018 10:54 pm Post subject: |
There are others but this is the first I came across, http://www.mg-parts.co.uk/index.php?route=product/product&product_id=82
When I said one and a half inches either side of centre that is three inches in total. My Morris 8 has about an inch either side and that is on a refurbished box, if the tracking and camber angles are correct then it shouldn't be a problem as the car should centre to a straight line with little wander, also make sure there is no lost motion in the drop links and track rod bushes. Still I suppose they didn't call them puddle jumpers for nothing! _________________ old tourer
