size is important
poorcol1964
PostPosted: Sat Jan 26, 2019 1:18 am    Post subject: size is important Reply with quote
hi , I'm planning on purchasing another classic car .
My question is : will i fit ?
I'm 6'5" and would appreciate your views on any pre 1960 saloon cars to avoid that could be a problem .
so if you have any sensible suggestions on models to avoid , let me know .
not interested in anything sporty or pre 1935 . just nice family runaround .
cheers
PostPosted: Sat Jan 26, 2019 9:54 am    Post subject: Reply with quote
Not the answer you want, but just illustrating a point Wink
Martin and Tom by Tony Brown, on Flickr
PostPosted: Sat Jan 26, 2019 10:08 am    Post subject: Reply with quote
Welcome to the forum.
I would imagine that most four-door saloons (above A35 size say) would accommodate a tall frame, after all this was still the era of gents wearing hats so they'd have to fit. Are there any cars already on your radar as possible buys?
PostPosted: Sat Jan 26, 2019 10:20 am    Post subject: Reply with quote
I think it's not just your height to consider - are you long-legged, or long in the body? You suggest you may consider pre-war cars; if you have long legs you may well still fit in an Austin Ruby, but if long in the body you may have to stoop to see out!
I am a long-legged 6 footer,and found there was plenty of room in my 1930 Morris Cowley ... once inside, but it was almost impossible to get in in the first place.
PostPosted: Sun Jan 27, 2019 7:09 am    Post subject: Reply with quote
Try a Rover P4. You have a choice of several different engines for the one chassis/body. Made from late 1949 to 1963. very comfortable and properly looked after very reliable.
They can accommodate drivers and passengers from quite a variety of sizes.
poorcol1964
PostPosted: Sun Jan 27, 2019 5:08 pm    Post subject: Reply with quote
to answer some of the points raised , 32" inside leg , 6'5" 19 stone .
i prefer earlier style cars , morris 8 , early anglia/pop/prefect . gullwing type engine covers etc.
PostPosted: Sun Jan 27, 2019 5:39 pm    Post subject: Reply with quote
It is easier to say which cars might suit rather than rule out ones that don't.
I would consider a Ford Consul/ Zephyr or perhaps an Austin A95 Westminster.
PostPosted: Sun Jan 27, 2019 5:57 pm    Post subject: Reply with quote
I'm 31" inside leg. I've just tried adjusting the seat in my Lancia Appia, and I can set it so that I can only just touch the brake pedal, and there's still room for me to sit in the back! It's only a little car - 1100cc - but there's plenty of internal space, and being an obscure Italian car that no-one has heard of, they tend to be quite cheap, especially in Series 3 form as seen on the left:
PostPosted: Mon Jan 28, 2019 9:48 am    Post subject: Reply with quote
Ray & Mike,
Why are you suggesting cars with crocodile bonnets when the OP wants "gull wing" type?
PostPosted: Mon Jan 28, 2019 11:22 am    Post subject: Reply with quote
Good point Peter. I hadn't made a note of that.
perhaps the Wolseley range should be considered. Plenty of head room in the ones I have encountered.
The 14.
alanb
PostPosted: Mon Jan 28, 2019 5:49 pm    Post subject: Reply with quote
What about a P3 or P2 Rover?
old tourer
Morris 8 two seater
poorcol1964
PostPosted: Mon Jan 28, 2019 7:12 pm    Post subject: Reply with quote
thanks peter .
i have nothing against your conventional car shape , horizontal boot ,bonnet etc.
it's just not my thing . there are some beautiful cars out there in that style , but i don't want one .
give me the ANT HILL MOB any day !
norustplease
PostPosted: Wed Jan 30, 2019 10:17 pm    Post subject: Reply with quote
Autin 10 Cambridge (1936-ish).
Mine accomodated my 6' 5" frame well. However, my Morris 10M (1946) was quite a squeeze to get into, although not bad once in (narrow doors).
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
JohnDale
PostPosted: Thu Jan 31, 2019 2:06 pm    Post subject: Reply with quote
Beautiful A95 would certainly tempt me(to each his(her) own.
Perhaps a visit to the main site which contains many, many cars for ideas.
Certainly much food for thought on there,cheers,JD.
1976 Ford Granada Ghia.
