Number plates.
PostPosted: Sun Dec 17, 2023 1:31 am    Post subject: Number plates. Reply with quote
On a classic car show that I saw last night - hosted by Drew Pritchard - they restored an NSU 80. Nothing exceptional in that you might think ...but something which Drew did had me wondering if it was legal. He replaced the original number plates with new. The difference was that where the original plates had a white reflective background to the front and yellow to the rear, his new ones were non reflective black background with raised aluminium letters/numbers all round.
I thought these traditional style plates were made obsolete on post 1973 vehicles...but I was wrong. From 1st Jan 2021, any vehicle constructed after 1st Jan 1980 can legally wear the older style plates.
How did I miss this?
PostPosted: Sun Dec 17, 2023 9:55 am    Post subject: Reply with quote
I still have a set of white on black plates from the Sunbeam Alpine I owned in the early 1970s because I swapped them for modern reflective ones. That said, I had several cars after that with white on black plates that I didn't change.
PostPosted: Sun Dec 17, 2023 11:17 am    Post subject: Reply with quote
Interesting. I must have been under the impression that there was no choice when in fact the reflective plates scheme was not compulsory at all!! Embarassed
PostPosted: Sun Dec 17, 2023 11:43 am    Post subject: Reply with quote
I have found the biggest problem when replacing B&W [or rather, in my case, aluminium and balck]...is finding a supplier who has the right font for the year of plate being replaced.
Fonts changed a lot [since 1951 in my case]....Especially when replicating pre-WW2 plates [ I had a Morgan with an original plate,it was painted , W&B]...
The font is as important as anything else kept original on a car..
PostPosted: Sun Dec 17, 2023 3:54 pm    Post subject: Reply with quote
Reflective plates were compulsory on all vehicles registered after 31st December 1972; it's only been in the last few years that the regulations have been relaxed (I thought it was now possible to have the old black-and-white plates on cars over forty years old). Personally I think cars from the mid-1970s look 'wrong' with the b&w plates, but each to his own.
Crashbox
PostPosted: Sun Dec 17, 2023 6:09 pm    Post subject: Reply with quote
When the rolling-40 was introduced for Tax/MOT exemption a legal loophole appeared that allowed the use of the older design of number plate. The Dept. for Transport closed that loophole a few years ago, so vehicles that had already reached 40-years-old were allowed to retain the older design if an owner had swapped over, but going forward (I think it's 1981 onwards) the older design of number plate (black/white, black/silver) is illegal. I agree that anything from about 1970 onwards just looks wrong on older plates. Most vehicles from the late-1960s had the black on white/yellow plates from new as buyers wanted to be seen to have the new style plate on their brand new car.
1989 2CV
1932 Morris Minor S.V. Two-Seater
PostPosted: Sun Dec 17, 2023 6:34 pm    Post subject: Reply with quote
In the programme, Drew Pritchard went to traditional a number plate manufacturer and had a new set stamped out from aluminium with a black background. I am surprised he was not advised as to the correct style of plate for the year....but then, the customer is always right. Razz
PostPosted: Sun Dec 17, 2023 9:05 pm    Post subject: Reply with quote
Incorrect plates , for me , stand out like a sore thumb! Countless classics have new replacement plates, normally b/w pressed aluminium in the wrong font for the period, most cars originally had raised digits rather than pressed. Pressed plates were more commonly found on commercial vehicles.
Black and white plates on pre 70s cars dont ,imho look correct, whilst not legally required until 72, most new cars from the late 60s were supplied new with reflective plates.
My own number plate restoration:
https://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=22313&highlight=
PostPosted: Sun Dec 17, 2023 9:54 pm    Post subject: Reply with quote
I would disagree with that. Plenty of late 1960's cars were fitted with non-reflective plates, even my old Triumph Dolomite was the Kennings' demonstrator registered 1st January 1972 and that was fitted with pressed black-and-white plates.
PostPosted: Sun Dec 17, 2023 10:52 pm    Post subject: Reply with quote
ukdave2002 wrote:
... most cars originally had raised digits rather than pressed...
Please can you explain the difference. My Swallow has original plates (as far as I know) and the digits are raised by having them pressed out. The plates are fairly heavy gauge aluminium.
PostPosted: Sun Dec 17, 2023 11:10 pm    Post subject: Reply with quote
Ray; those are like the ones on our '34 Austin Ten Four in '59 I doubt they had been changed from new..
PostPosted: Mon Dec 18, 2023 12:34 am    Post subject: Reply with quote
I think the square plate was originally mounted on the back with a single lamp over but when I found it fitted perfectly between the front valance projections, that allowed me to fit the long plate on the spare wheel carrier with two D lamps (tail & stop).
The only disadvantage is that should I need to remove the spare wheel, the number plate and rear lights have to come off to get to it.
I suppose there are always compromises to be made.
bjacko
PostPosted: Mon Dec 18, 2023 6:33 am    Post subject: Number plates Reply with quote
The older number plates used to be a variety of types produced by different manufacturers. Most were like the Swallow bodied car belonging to Ray pictured above, but some "upmarket" cars had the raised numbers and letters fitted individually. Never liked them as they were harder to clean and often came loose. I think some of them were plastic letters and numbers.
I think Bluemels used to supply both. Most were ordered and fitted by the new car dealers.
1985 Rover SD1 VDP
PostPosted: Mon Dec 18, 2023 9:42 am    Post subject: Reply with quote
Well, for my two pennies worth, I'm in agreement that Black and silver plates simply don't look right on cars from the 70's onwards.
PostPosted: Mon Dec 18, 2023 10:16 am    Post subject: Reply with quote
Agreed
