Posted: Tue Sep 16, 2008 7:01 pm Post subject: BSF Bolts & Screws |
I have just been making a shopping list of the various bolts, set screws etc that I need to build up the Morris 8, am finding that the price of anything BSF is astronomical!! over 50p for a single 1/4" * 1" BSF bolt!! not even looked at the bigger bolts I need.
Have looked at all the usual suppliers, anyone know of a cheap source for BSF stuff?
Ta Dave |
Posted: Tue Sep 16, 2008 7:05 pm Post subject: |
I've used this company in the past, they are very helpful and give good advice. Local to me so if they don't post I could collect and post for you
Robert Livingstone (Paisley) Ltd
33, Abercorn St, Paisley, Renfrewshire PA3 4AL
Tel: 0141 889 2955 _________________ ROVER
One of Britain's Fine Cars |
Posted: Tue Sep 16, 2008 10:10 pm Post subject: |
I usually get mine at the autojumble at various events throughout the year. _________________ The Clan Chieftain |
Posted: Tue Sep 16, 2008 10:23 pm Post subject: |
They are dearer but where a plain nut/bolt fixing is required UNF will be the same diameter and not many would notice the slightly different head size. These are very much more cheaper and have a larger variety of lengths as BSF have less choice now. Even stainless UNF can be used in places where high tensile fixings are not required.
I think I spent well over £200 on BSF fixings 9 years ago when restoring my 1968 Rover 16.
Beware using metric as these are smaller diameter but again it depends where they are being used _________________ Rover P2
Posted: Thu Sep 18, 2008 9:18 am Post subject: |
47p2 wrote: | I've used this company in the past, they are very helpful and give good advice. Local to me so if they don't post I could collect and post for you
Tel: 0141 889 2955 |
Thanks for the offer 47p2, I may take you up on it, I going to work out exactly what I will need rather than the first plan which was to buy a load on a guestimate! |
Posted: Thu Sep 18, 2008 12:32 pm Post subject: |
Let me know your shopping list and I will visit the shop and speak with them _________________ ROVER
Greeney in France
Posted: Thu Sep 18, 2008 7:38 pm Post subject: |
Just found this
http://www.bernie-bolt.com/ _________________ www.OldFrenchCars.com
Posted: Thu Sep 18, 2008 9:00 pm Post subject: |
Greeney, are you aware that the nuts and bolts on your Traction probably arent the current metric standard? |
Greeney in France
Posted: Thu Sep 18, 2008 9:10 pm Post subject: |
Yes I already found that out with a bolt that wasnt 13mm or 1/2inch
Bugger!!
Enlighten me what standard was it? besides French!! _________________ www.OldFrenchCars.com
Posted: Fri Sep 19, 2008 7:31 am Post subject: |
Greeney, I'll start a new topic on this subject to avoid hijacking this one! |
Posted: Fri Sep 19, 2008 10:43 am Post subject: |
Phil - Nottingham wrote: | They are dearer but where a plain nut/bolt fixing is required UNF will be the same diameter and not many would notice the slightly different head size. These are very much more cheaper and have a larger variety of lengths as BSF have less choice now. Even stainless UNF can be used in places where high tensile fixings are not required.
Beware using metric as these are smaller diameter but again it depends where they are being used |
I have fitted several UNF bolts in place of BSF but it's a dangerous road to go down.... with the 1/4" there is only a difference between 26 and 28 tpi (I believe)
which means the nut will go on to the bolt and then tighten up after a couple of turns. Getting them mixed up (in a large box of odds and ends)
can provide many hours of innocent enjoyment when you need one or the other. I have a box like this. _________________ Due to the onset of my mid eighties I'm no longer sprightly and rarely seen in my Austin special. I have written a book though. https://amzn.eu/d/7rwRRqL |
Posted: Fri Sep 19, 2008 10:38 pm Post subject: |
I did not mean to suggest in any way mix/match nuts/bolts only to use them paired where they bolt things together as a most old cars were as regards bodywork and on my Rover 16 parts of the steering/suspension and brakes.
I never did find a supplier of BSF captivated square nuts but used ordinary BSF nuts just to keep a standard thread size throughout as original although I do not really think it was worthwhile doing this _________________ Rover P2
