Posted: Thu Jan 07, 2010 10:32 pm Post subject: Drilling case hardened steel |
I need to drill a case hardened shaft, any recommendations on the approach / type of drill? I don’t really want to use any heat. The holes don't need to be very accurate , looking on the web using masonry drill bits is one suggestion ?
Al advice welcome
Posted: Fri Jan 08, 2010 1:18 am Post subject: |
Dave,
I don't know what sizes they come in but there are special diamond bits for drilling ceramic tiles. May be worth investigating.
Uncle Alec
Posted: Fri Jan 08, 2010 9:57 am Post subject: |
I would have thought that a HSS cobalt bit, slow speed , and Rocol or sim drilling/tapping lube should do it. |
Posted: Fri Jan 08, 2010 12:33 pm Post subject: |
How about cutting a notch with an angle grinder first?
Posted: Fri Jan 08, 2010 2:02 pm Post subject: |
If you can find a local tool maker maybe you could have the holes spark erroded??
PAUL |
Ghost
Posted: Sun Jan 10, 2010 12:11 am Post subject: |
I go to model engineering exhibitions, just to gawp, my skills don't reach that far! But there are micro grain tungsten solid carbide drills for sale. Yes they are expensive, and no I don't have any, guess why! I would try one of these. Any decent model engineers supplier would advise on drill speed and lubricant too. Let us know how you get on. |
Posted: Mon Jan 18, 2010 9:32 am Post subject: |
Thanks for all the advice The challenge in question concerned cross drilling the oil ways in a new layshaft I was making for the Morris 8 gear box. The original one had about 20 thou wear, and new ones are not available. Drilling the oil way through the length of the shaft was not a problem as its only the case that was hard. I had forgotten that the original shaft had "flats" where the oil holes were, so had to mill through the case hardened steel (rather than just drill). Normal milling bits just wouldn't touch it, so I ended buying a solid cobalt 8mm 3 flute mill and with some light cuts milled through the case hardening. I have never done any milling before so probably not the best job to start on ! ( it was a good excuse to buy a vertical slide for the lathe tho !)
Anyway it worked, the final drilling was the a straight forward job.
You can just make out the wear on the original shaft on the photo above.
Cheers again
Posted: Mon Jan 18, 2010 10:11 am Post subject: |
Very nice!
Proper engineering.
Dodgealpine
Joined: 18 Mar 2008 Posts: 23 Location: Blackburn, UK
Posted: Thu May 20, 2010 8:53 pm Post subject: |
Glad you sorted it. One solution is to use a "Dremmel" or such like, using a grinding bit just to get through the hard case then you can drill it. |
