Posted: Mon Jan 11, 2010 9:43 pm Post subject: keyway, what type? Removal |
Slight blond moment, but I have a gear with a knock in key, that holds the gear on, what is the proper name for this key?
Posted: Mon Jan 11, 2010 9:45 pm Post subject: |
Woodruff key if you mean the 1/2 moon type which is just a bit off the top of a circular steel disk _________________ Rover P2
Posted: Mon Jan 11, 2010 9:53 pm Post subject: |
Just came to me the word was tapered this led onto gib!
So how do you remove a very tight gib key, that has no head, for a gib puller?
Posted: Mon Jan 11, 2010 10:21 pm Post subject: |
I have seen these used on engines, but you have to have a head for it to slot behind, mine doesn't seem to have any head left, or it has been hit that far in it has gone.
Either way a gib key puller won't work.
I am tempted to get a big puller and just give it a pull, but I think it will break the sproket as it will just get tighter!
I need this sproket off to source/replace the bearing that has completeley collapsed, snapping the chain in the process, and the chain is really quite large, must have gone with a wollap! hehe
victor 101
Posted: Mon Jan 11, 2010 11:07 pm Post subject: |
Any chance of putting a bit of weld on it to give the puller something to hang on. |
Posted: Tue Jan 12, 2010 12:21 am Post subject: |
I might have to do that, a few blobs on the top corner, it is very short indeed, but might be enough.
dclf1947
Joined: 23 Nov 2007 Posts: 107 Location: Laoag City, Philippines
Posted: Tue Jan 12, 2010 12:15 pm Post subject: |
If the gear is not against a shoulder you can try driving the gear forward a little to release the key.
Philippines |
Posted: Tue Jan 12, 2010 7:20 pm Post subject: |
Well I have done it.
I drove the sprocket forward as far as I could with a copper hammer, it went a little, 3 or 4 mm, but it didn't release the key. So I got the big pullers out, and pulled the sprocket off, with the key still in there, it came out ok in the end.
Cheers for all the replies!
