poodge
Posted: Sat May 15, 2010 10:47 pm Post subject: |
I'm not really into these vacuum cleaners,I like my airplanes with the bang-bang on the front
All the same it's sad to see historic material being scrapped.But I suppose you can't keep everything.Where to draw the line? |
Posted: Mon May 17, 2010 8:59 pm Post subject: |
Been there even longer
I can remember driving past it in my Lorry in the mid, or even early 80's
Roger |
Posted: Mon May 17, 2010 9:30 pm Post subject: |
Hi Roger. Travelling South, wasn't it just before a water tower or similar on the opposite side. I seem to remember the road went slightly uphill. I last travelled that piece of road in the late 1990's but I did it quite a few times around 1983-6. |
XL391
Joined: 07 May 2008 Posts: 147 Location: The Red Side of Liverpool
Posted: Tue May 18, 2010 6:35 pm Post subject: |
Roger-hatchy wrote: | Been there even longer
See here, taken from the excellent Thunder & Lightnings website. _________________ Regards,
Will
1972 Daimler Sovereign 4.2 Series 1
1965 Sunbeam Tiger Mk1
1968 Triumph 1300 |
Posted: Tue May 18, 2010 11:50 pm Post subject: |
XL391
I can still FEEL them now.
I saw a scramble of four in two pairs in quick succession doing the usual tail stand at the end of the runway in Germany in the 60's
Can also remember four Vulcan doing the same, not in pairs though, in Tengah, Singapore in 64 or 65.
Just as impresive was a DH comet doing the same departing Kuching about 0300hr after an engine problem left it empty and an early departure.
Roger |
P3steve
Posted: Wed May 19, 2010 8:30 am Post subject: |
Living near the now just closed RAF Coltishall air base in Norfolk the family and I would often spend an afternoon there with a picnic plane spotting there was a track/ footpath that led to an emergency access gate where you could get to within 100 yards of the end of the runway and still be on public land and as the Jaguars lined up in pairs on the end of the runway running up there engines ready for take of the pilots would wave to us giving thumbs up etc. When they throttled up you could feel the pressure in the air and had to cover your ears - great stuff though and if you followed the foot path you could walk past the end of the runway as the planes came in to land passing only about fifty feet above your head, it was amazing how many other planes would use the runway for landing practice doing touch and goes, you would often see American planes from Mildenhall and have also seen a pair of Hercules do several runs just touching the ground then going to full power to pull up again and have on many occasions seen Canberra's do both touch and goes and landings at the base once also saw a VC10 land as well. All gone now as the base closed a few years ago but we also used to go up to RAF Marham near Kings Lynn and watch the Victor tankers take off labouring to climb with a full load on, all in the past now but was glad to have had the chance to see it. The Americans were a bit more touchy and if you stopped on the road or any public area near the fence at Mildenhall within five minuets an American security/police car would draw up on the other side of the wire and sit watching you and on one occasion we were told to move on even though we were on a main A road with no (at the time) stopping restrictions out side the American area of control. |
Riley Blue
Posted: Wed May 19, 2010 9:22 am Post subject: |
This would look good on my front lawn
Posted: Wed May 19, 2010 11:10 am Post subject: |
You see alot of aircraft in playgrounds, like you did steam rollers, the steam rollers have become a rarer sight now with there value increase, councils sold them off, and also the health and safety factor probably played a part, aircraft will probably go the same way!
I remember playing in a SeaKing helicoptor when I was little, I could never get into the cab, as I wasn't tall enough, in the same park was a Tank of some sort, not sure what it was, it was all welded closed, as to not get in side.
Posted: Thu May 20, 2010 9:22 pm Post subject: |
Damn you BB
You make me feel old, the Seaking hadn't even flown when I finished my service career.
I think the bigest we had was the time was the Wessex.
Roger |
XL391
Posted: Fri May 21, 2010 8:47 am Post subject: |
Roger-hatchy wrote: | XL391
And you still can if you want to Roger! Ableit, they won't be standing on their tails and blasting into the wide blue yonder... However, the LPG's pairs run aborted take off is probably the noisiest thing i've ever heard! Have a look at their website below, and the website for XS458 @ Cranfield in Bedfordshire (you can ride in this one!) Both organisations are running their aircraft in the next few weeks, have a look at their websites to see when, they're well worthwhile catching!
The Lightning Preservation Group
Lightning T5 XS458 _________________ Regards,
Will
1968 Triumph 1300 |
Posted: Fri May 21, 2010 9:06 am Post subject: |
XL391 wrote: | Roger-hatchy wrote: | XL391
Lightning T5 XS458 |
Cooo wouldn't mind a ground ride in that one!!
Some years back, I found myself near to Bruntingthorpe so called in on the off-chance I could get in, which I did. Happily, there were static engine tests underway on a Lightning. Seeing the thing bouncing on the brakes as they opened her up was something else
Joined: 23 Nov 2007 Posts: 4762 Location: Swindon, Wilts.
Posted: Fri May 21, 2010 7:42 pm Post subject: |
I worked at Patchway for BS/RR between '66 and '70.
It was a dispersal field for the Vulcans, when the were running up and doing a scramble TO the whole factory shook.
They were much louder and had more bottom end vibration than the Olympus 593 test bed Vulcan which was based there. _________________ Bristols should always come in pairs.
XL391
Posted: Sat May 22, 2010 12:14 pm Post subject: |
Rick wrote: | Some years back, I found myself near to Bruntingthorpe so called in on the off-chance I could get in, which I did. Happily, there were static engine tests underway on a Lightning. Seeing the thing bouncing on the brakes as they opened her up was something else |
Yep, that's Andy and the boys mate! They're a friendly bunch to boot. They're there most weekends doing one thing or another.
One of my mates did them a good turn a few years back, the result being he got to be brake man in the cockpit when she was being towed out for an engine test and he got to stand next to it when they were doing the test! Jammy bar steward...
At least one of these will be blasting up Brunty's runway next Sunday for anyone who's interested...
Will
1968 Triumph 1300 |
