petelang
Posted: Fri Jul 09, 2010 8:43 pm Post subject: DS420 jag engine - Funny noises! |
Hi all,
I have a DS420 with the jag 4.2 engine fitted.
It has developed a funny little knocky noise (like a light tapping) when idleing. Just does it for a few seconds, like tap, tap, tap, tap...then nothing, then about five mins later same again.
I've not had it long so no history. It does run a bit rough, despite overhauling Carbs and jumps about a bit if idle below 700.
Any Jag mechainics offer a bit of advice? Tips what to look for?
Regards,
Peter |
victor 101
Posted: Fri Jul 09, 2010 11:10 pm Post subject: |
Timing chains?. |
Kelsham
Posted: Mon Jul 12, 2010 2:55 pm Post subject: funny noise |
I seem to recall that the valve guides can come loose on these engines and cause a tapping noise. I believe there is a repair involving fitting a plate to hold them down.
regards Kels. |
Car-Nut
Posted: Thu Nov 25, 2010 1:01 pm Post subject: |
Hi Peter,
Not wanting to direct you off the forum but go to Jag Lovers theres an xk engine section with some very knowledgable guys on there.
Of course keep us posted with any updates _________________ Car-Nut
'62 S1 Jaguar E-Type 3.8 FHC
'70 420G - 13th from last RHD
'70 420G - 17th from last RHD |
