dave 35
Posted: Thu Nov 25, 2010 1:08 pm Post subject: ENGINE WIRING |
I wondering if someone out there can help me. Can anybody explain to me in basic english (idiot terms) or even draw a diagram as to how to wire up an 1930's straight 6 engine for out of car testing. Any help would be very much appreciated.
regards Dave35 |
victor 101
Posted: Fri Nov 26, 2010 6:06 pm Post subject: |
First of all make sure the engine is not going to topple over when it fires up (hopefully). Its probably positive earth, so connect a jump lead from the battery + to the engine block, connect a wire to the sw side of the coil and to the - terminal, the other jump lead connect to the main starter terminal and by pushing it against the - terminal on the battery you should be turning over. |
dave 35
Posted: Sat Nov 27, 2010 11:47 am Post subject: engine wiring |
thank you for taking the time to answer my question. I will attempt to start the engine over the this weekend. many thanks again.
dave 35 |
