Posted: Mon Dec 13, 2010 9:35 pm Post subject: E93a or 100E |
On the look out for an e93a, preferable, or a 100e engine.
No need to be prestine as will be rebuilding with Aquaplene modifications.
A short engine would be fine.
Be handy to have a spare, the one in the DLM has had max size rebore last recon. +40 pistons.
So if anyone hears of one available feel free to let me know
Thanks
Roger
PS cheaper the better |
Posted: Tue Dec 14, 2010 4:40 pm Post subject: |
Thanks Rick
I have the E93 in at the moment.
That is why E93 would be first choice.
I have been told by "Smallfordspares"
Timeing cover needs changing, one bolt hole of the gearbox to engine will be out of line, and a hole needs cutting in the bellhousing to fit the 100e starter.
Will have to look into how much modification needed to use the 100e gearbox. car might not be long enough, the propshaft is only about 3 foot long.
Mind you once the crankshaft oil seal is done should be good for a few more miles yet, about 5000 miles now since recon.
Roger
PS it would be the 10hp I'm looking for |
Posted: Sun Jan 02, 2011 2:39 pm Post subject: |
Might have a couple of engines and sundry ford prefect parts.
Two engines e93a
One might be a recon engine, some nuts and exterior bits missing.
Second came out of the car with an exchange, car now changes for 100e
Prefect
Bonnet,screens, carbs, Distributors, lights, glass, grill and other parts.
Job lot £150
Just got to organise transport, van or trailer, to collect from Radcliffe
Roger |
