How can i add indicators with Hazard
fordf350camper
PostPosted: Tue May 10, 2011 10:04 pm    Post subject: How can i add indicators with Hazard Reply with quote
Whats the best way to wire up indicators with hazard lights.At the moment i only have trafficator but still would like them to work but seprate.Do you have a wiring daigram.Thanks
traction39
PostPosted: Tue May 10, 2011 11:00 pm    Post subject: Reply with quote
look here:
http://www.autoelectricsupplies.co.uk/file_uploads/aes_catalogue_5.pdf
The AES catalogue has many combinations of wiring for hazards, semaphores extra lights etc.. page 90 onwards of downloaded file.
Alistair
oldtimer
PostPosted: Wed May 11, 2011 9:33 am    Post subject: hazard lights Reply with quote
The way I did this gave me hazards for emergency use.If you have a socket for trailer lighting fitted to your car.Simply identify,with a test light,which pins are for left and right indicators then get a plug to fit this socket.Take short lengths of wire from the pins which will mate with these indicators.Join them together and fit to a spade terminal .Use a small flasher relay and connect the spade to this .The other earth pin on the relay was connected to the appropriate pin on the plug,
With the ignition switch but without starting the car the indicator switch will activate the hazards.
Now a warning this device cannot be left permanently in place and is only plugged in temporarily in a genuine emergency.Secondly the coil should be disconnected during use to protect it from damage.Just keep the thing handy in the glove compartment and plug it in if/when needed
PostPosted: Thu May 12, 2011 12:32 am    Post subject: Reply with quote
Go to page 86 of Alistair's catalogue. There's a kit there for £15.00. It's for 12 volt only though. Item No. 170902.
Art
PostPosted: Sun May 22, 2011 8:47 pm    Post subject: Reply with quote
Conjures up an image of old cars with both trafficators flapping like a penguin!
Peter Laughing
1stpop
PostPosted: Thu Jul 14, 2011 9:07 pm    Post subject: Reply with quote
I added indicators to my Morris 8 and then just added an extra switch that connects both sides together - switch on indicator and lick the switch for hazards - can supply a simple diagram if you like?
