1stpop
Posted: Sun Jun 19, 2011 1:23 am Post subject: Morris 8 Series E Rear Shocks |
Can anyone tell me what type of shocks should be fitted to the rear of my 1946 Morris 8 Series E? Also where could I find some from? Any pictures of the correct set up would be a great help. |
Posted: Sun Jun 19, 2011 8:13 am Post subject: |
I'll post a pic later, its quite a simple set up; Armstrong lever arm shock with a straight link to the leaf spring.
Below is a pic the shock fitted to my 39 SE they were unbranded not oil filled, the links were the same dimensions as the Armstrong setup;
It now has the original Armstrong set up.
Posted: Sun Jun 19, 2011 6:05 pm Post subject: |
Rear shocks with original Arnstrong set up;
I have a box of M8 SE shocks, so give me a shout if you need some.
1stpop
Posted: Mon Jun 20, 2011 5:21 pm Post subject: |
thanks - when I had a good look I found that someone had attached a modern stlye shock from the spring to the old shock arm and this is now touching the bottom of the car! Guessing the old shocks have had it - some type as the second picture. |
1stpop
Posted: Thu Jun 30, 2011 9:16 pm Post subject: |
Yes I would be interested in getting a couple of shocks if posible - do you also have any of the connecting arms? |
