steammart
Posted: Mon Aug 01, 2011 2:26 am Post subject: 1937 Morris 8 series one - the rot box! |
Hi All
For those that did not see my introduction, a few months ago i purchased a morris 8. I was told that it had been parked up in 1970 and not moved since (this has since been backed up by a fellow Morris 8 owner)
She was a non-runner but with a bit a fiddeling i managed to get her running. Everying worked to my suprise, guages showed she had oil pressure that dynamo was charging and even the lights worked.
I have now begun the long process of a full restoration. This is my first car restoration and i am relatively young (23) so it will no doubt be a learing curve too. Due to work, and other hobbys (miniature traction engines) my time on the car will be limited, but i will try and keep this updated with progress or the lack of it.
So enough of my rubbish and now i will show you some pictures of 'Pearl' as she now has been named. All comments welcomed.
Martin |
steammart
Posted: Mon Aug 01, 2011 2:36 am Post subject: |
This is where 'pearl' sat for 41 years under this car port in a little village nr Middlesbrough.
just a few of her condition
and loading her up (thats my ugly mug in the photo)
Posted: Mon Aug 01, 2011 8:31 pm Post subject: |
Well it may have a bit of rust but the seats have beautiful patina which is much more difficult to recreate if they had been missing or beyond repair.
Peter. _________________ http://www.nostalgiatech.co.uk
doug
Joined: 12 Aug 2008 Posts: 128 Location: s. w. scotland
Posted: Mon Aug 01, 2011 10:08 pm Post subject: |
It honestly looks pretty fresh!! Keep the photos coming of progress. |
pryantcc
Posted: Mon Aug 01, 2011 10:44 pm Post subject: |
I agree, the seats look great! In the third photo, is that some kind of luggage rack on the back?
The best of luck with the restoration, looking forward to following your progress! |
steammart
Posted: Wed Aug 03, 2011 1:33 am Post subject: |
Forgot to say pearl is a 2 door sliding head saloon black/green.
I am going to try and keep the interior as original as possible. the back seat isn't very clever though (will post pic later)
pryantcc - Yep certainly is a lugage rack (i am told it is the 'rarer' type fitted to the morris 8's)
Few more before i begun
To get her running a temporary fuel tank was rigged up. points changed, cleaned carb and a bit of tinkering, and hey presto!
pictures of her running with her lights working after all those years
Marty |
Posted: Wed Aug 03, 2011 1:07 pm Post subject: |
Cracking find! Great to see someone under 25 interested in a real motor car and not some mass produced junk or something with an exhaust the size of a bucket.
The very best of luck with it!
Paul |
Nic Jarman
Posted: Wed Aug 03, 2011 7:20 pm Post subject: |
Ah that brings back memories! MOT for mine on friday. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Thu Aug 04, 2011 7:58 am Post subject: |
Nic Jarman wrote: | MOT for mine on friday. |
Hope all goes well Nic. |
steammart
Posted: Wed Sep 21, 2011 6:01 pm Post subject: |
With work and going to steam rallys i havent got much done on pearl, but this is how she is at the moment.
She currently looks like this
The rear arches and accross the back of the body had fibre glass all over, i knew it wouldnt be hiding anything good, but tin worm has well and truely got hold of her and then been bodged up.
before:
some of what i removed
and the degree of the tin worm
Well thats it for now
within the next couple of weeks should be able to tackle her a bit more
Martin |
Kelsham
Posted: Thu Sep 22, 2011 9:24 am Post subject: rot box |
Look on the bright side, the fibre glass repairs probably saved her for you today.
Back in the 1960s it was considered a perfectly acceptable way to repair old bangers.
Happy days.
Just do a little at a time, it is surprising how you will make progress.
I try to do work on my projects at least three times a week.
A couple of hours at a time. Usually time worked extends once I begin.
Regards Kels. |
Nic Jarman
Posted: Fri Sep 23, 2011 8:55 am Post subject: |
It always looks a lot worse than it is. Don't try to lift the body by yourself. I am looking forward to your posts. Good luck. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
