Suicide Jockey
Posted: Wed Nov 09, 2011 10:15 pm Post subject: Pemberton stove??? |
I am restoring a Pemberton static from around 1961 which is original and complet except for a missing solid fuel stove and 'fancy' flue. Later models had an airing cupboard above the stove covering the flue.
Does anybody have any images or brochures showing this stove so that i can start the hunt for the correct one?
This Pemberton is the one with the round ends! I am not sure how to upload a pic!
thank you steve |
moggy
Joined: 28 Jul 2008 Posts: 174 Location: MIDDLESBROUGH
Posted: Sat Nov 12, 2011 9:50 pm Post subject: Re: Pemberton stove??? |
Suicide Jockey wrote: | I am restoring a Pemberton static from around 1961 which is original and complet except for a missing solid fuel stove and 'fancy' flue. Later models had an airing cupboard above the stove covering the flue.
thank you steve |
hope this helps http://s718.photobucket.com/albums/ww185/margyduff/?action=view¤t=100_0040.jpg there is some bluebird stuff there as well as other enjoy.The stove is a pemberton stove in my bluebird. I may have a spare one but will have to dig it out of my 40ft storage container ,will take about up to 2 weeks,nand will let you know. _________________ All my favourite memories are in the past. |
Suicide Jockey
Posted: Tue Nov 15, 2011 7:48 pm Post subject: |
Hi Moggy......... that is exactly the stove!!!!!!! My Pemberton is the Starlite and sales adverts correspond with your stove. Coincidentally I have the same Bluebird as yours but it was never fitted with a stove! Maybe it was an optional extra?
If you do manage to locate a spare stove I would be very interested in purchasing.
thank you steve |
Dalek63
Posted: Sun Nov 20, 2011 11:31 am Post subject: |
I found this advert in one of our Caravan magazines, looks like the same sort of stove.
Hope this helps. _________________ I can resist anything except temptation ! ( Oscar Wilde)
Suicide Jockey
Posted: Sun Nov 20, 2011 5:39 pm Post subject: |
Thank you.... yes the ARTAYCO were used in Pembertons and some other makes for a while. I think these slightly predated the type mentioned by Moggy above. Probably mid to late 50's. A good looking stove.
I bet there is not many of these stoves left? |
moggy
Posted: Sun Nov 20, 2011 6:49 pm Post subject: |
the stove i have has pemberton just below the front pull down door. _________________ All my favourite memories are in the past. |
Suicide Jockey
Posted: Mon Nov 21, 2011 11:04 pm Post subject: |
moggy wrote: | the stove i have has pemberton just below the front pull down door. |
Thats the one for me!!!!!!!!!! |
Dalek63
Suicide Jockey
Posted: Wed Nov 30, 2011 12:06 am Post subject: |
Yes I think that is the type ...... thanks for he heads up. |
