UKdave2002 Guest
Posted: Tue Mar 06, 2007 11:00 am Post subject: Mig Welder |
I’m going to replace my mig welder, currently have a Clarke 100E which has served me well for 15 years, but is now just worn out & a tad under powered, (if anyone wants it they can have it.)
Looking for something with at least 150 amp capacity, there are loads on the market,various prices, but what are the features to look for?
Someone has advised me to look at the output voltage, his advice being that a higher voltage will produce a more consistent weld as the arc is easer to maintain, this seems logical and the more expensive migs tend to work at a higher voltage.
I have also read about migs that can auto adjust the wire speed to match current setting , what are your views?
Uncle Joe Guest
Posted: Tue Mar 06, 2007 5:40 pm Post subject: |
UK, look at the bottom end performance - I'm assuming you are going to be working on the thin sheet metal of cars. With the correct choice, you can go down to maybe 0,5mm.
Easy polarity change, if you fancy getting a bit advanced, is another thing to look for.
I do have my favourite manufacturers, but I am rather reluctant to recommend any of them!
UJ |
UKdave2002 Guest
Posted: Tue Mar 06, 2007 6:01 pm Post subject: |
UJ
Do you only need the polarity change if using both gas and gasless wire? |
Uncle Joe Guest
Posted: Tue Mar 06, 2007 6:29 pm Post subject: |
Well, no. Personally, I can never notice any improvements gained by changing the polarity for gas or gasless wire. Though I know plenty people that do. Maybe its just 'my' style of welding!
Its when I'm welding rusty or dirty metal that I change the polarity, its an old trick!
As far as amperage goes, do you know how much can you use off UK single phase? Is 180A possible? That would be my minimum. Its so long since, I've forgotten!
UJ |
UKdave2002 Guest
Posted: Wed Mar 07, 2007 9:17 am Post subject: |
Can you weld rusty metal with a mig? |
buzzy bee Guest
Posted: Wed Mar 07, 2007 9:58 am Post subject: |
You can weld rusty stuff with mig, if you try hard, but it is near imposible with tig, in my oppinion! But I have never done Tig so don't quote me on that!
Uncle Joe Guest
Posted: Wed Mar 07, 2007 11:40 am Post subject: |
Buzzy, you are spot on with your comments.
TIG welding rusty metal is near impossible!
MIG welding is possible, as long as its not to bad, ie, there is some good metal under it somewhere. There are a couple of 'tricks' to learn though!
UJ |
buzzy bee Guest
Posted: Sun Apr 01, 2007 9:15 pm Post subject: |
UJ
What are these tricks then?
john-saab Guest
Posted: Sat Apr 07, 2007 9:35 am Post subject: |
Try this site for welding tips...its one of the best i have seen...
welding help |
buzzy bee Guest
Posted: Sat Apr 07, 2007 10:12 am Post subject: |
Cheers for the link I will have a look, I am all up for improving my welding skills.
