Stationary Blades
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical
Julian
PostPosted: Fri Mar 09, 2012 4:36 pm    Post subject: Stationary Blades Reply with quote
Well that's what ''Vehicle Wiring Products'' call them!
If you scroll down this page:
http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/noninsblades.php
you'll see them, I'm after SBB or SBG but not in the common size of 6.3mm. It's the next size up which is (I believe) 10mm that I need, having looked everywhere including ebay, I've failed - any suggestions?
Ta Julian.
PostPosted: Fri Mar 09, 2012 5:07 pm    Post subject: Reply with quote
some 9.5mm SBG here, they are 9.5mm because its close to 3/8":
http://www.autoelectricsupplies.co.uk/product/7/category/2
PostPosted: Fri Mar 09, 2012 6:38 pm    Post subject: Reply with quote
What happened to LUCAR? did he die!
Who are the clever people who change names? And where did they get the idea there can be a FEMALE blade? Mad Is it something to do with a sex change?
Jim.
Julian
PostPosted: Fri Mar 09, 2012 8:55 pm    Post subject: Reply with quote
Thanks Dave, that'll do the trick nicely - it's for an ammeter on a Massey 135 tractor. I guess 3/8'' is the size, just nowadays rounded to the nearest mm as retailers aren't allowed to sell stuff in imperial nowadays! (Dam EEC bureaucrats Sad )
BTW I've not heard or seen the ''Lucar'' word for about 30 years!
Julian.
PostPosted: Sat Mar 10, 2012 8:53 pm    Post subject: Reply with quote
Julian.
Glad that fits the bill, if you need an unisulated crimper tool give me a shout!
NONORT
PostPosted: Sat May 26, 2012 4:26 pm    Post subject: Reply with quote
Cool Not realy part of this thread but. I found out by experimenting that the crimp on bullet conectors that have insulation on them are heat sensitive. If you fit then onto the cable then heat with a heat gun they shrink and become water tight as well as almost imposible to get a part handy if you are burying the conector in some god forasaken place in the bowels of your car, truck etc. Dont see why this would not work with other types of conector with a simular insulated covering. Sorry for hyjacking this post.
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical All times are GMT + 1 Hour
Halfords
