Posted: Mon Apr 02, 2012 7:54 am Post subject: What Battery |
What battery do I buy to power my flashing beacon, obviously it needs to last as long as possibe, as it won't have any charging untill I get home, it will only have a beacon on it mind.
emmerson
Posted: Mon Apr 02, 2012 10:57 am Post subject: |
I'd go for what they call a 12x12. These are used on small mobillity scooters, and seem to go on for ever. I have a spare one for herself's stand-by scooter. It's nevere been used on the machine, but I use it to jump start my ride on mower, and in two years I've never yet charged it.
About £30 as I remember. Also used on golf buggies, I believe. |
emmerson
Posted: Mon Apr 02, 2012 11:07 am Post subject: |
Joined: 23 Nov 2007 Posts: 4115 Location: South Cheshire
Posted: Mon Apr 02, 2012 1:27 pm Post subject: Re: What Battery |
buzzy bee wrote: | Hi
I'd go for LED flashing strobes, as seen on recovery vehicles, will give you much more battery life than a rotation beacon lamp....can't you strap a generator on somewhere?
Posted: Mon Apr 02, 2012 2:20 pm Post subject: |
Can they not be solar powered / charged these days.
And yes LED would be less power consuming in another way, no power to a motor that turns the beacon. |
Posted: Mon Apr 02, 2012 8:22 pm Post subject: |
I have been looking at strobes etc, not decided on what to do yet, so many to chose from.
I have seen lots of engines with a alternator under the flywheel, wich powers head lamps and a battery obviously, but I am not keen on it att the moment, for the ammount I plan to do... Would it matter an alternator going backwards?
Posted: Mon Apr 02, 2012 8:30 pm Post subject: |
No as output is same in either direction before rectification surely _________________ Rover P2
Posted: Mon Apr 02, 2012 10:03 pm Post subject: |
Dave.
The cooling fan would be the only problem. Sucking instead of blowing.
Posted: Mon Apr 02, 2012 10:11 pm Post subject: |
oh, thats the alternator off the list of ideas then, asI need to be able to reverse up ocasionally... lol |
Posted: Tue Apr 03, 2012 7:53 am Post subject: |
Buzzy
See if these would do the job:
4 modes - bright white, red. green & flashing red. 40 hours run-time (maybe) on 3 little AAA batteries - included.
A local store in the US was selling these for $3.50 a pair a few weeks ago. I bought a dozen for use at the trolley museum that I volunteer at. If there's any left I'll get some more - e-mail me off-list if you want a couple.
http://www.ebay.com/itm/Brinkmann-9-LED-Multi-color-Flashlight-/320879363125?pt=US_Flashlights&hash=item4ab5e68435
MVPeters @ comcast.net _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Tue Apr 03, 2012 10:14 am Post subject: |
47Jag wrote: | Dave.
buzzy bee wrote: | oh, thats the alternator off the list of ideas then, asI need to be able to reverse up ocasionally... lol |
For the low power you need cooling won't be an issue, also if air is sucked through the alternator rather than blown it will still cool.
Posted: Tue Apr 03, 2012 10:26 am Post subject: |
Art | quote="buzzy bee"]oh, thats the alternator off the list of ideas then, asI need to be able to reverse up ocasionally... lol[/quote]
Posted: Tue Apr 03, 2012 3:34 pm Post subject: |
If you run the alternator backwards AC output will flow backwards and forwards - instead of forwards and backwards!
Julian
Posted: Tue Apr 03, 2012 4:25 pm Post subject: |
'tis a centrifugal fan. So works the same what ever the direction of rotation.
Though to be fair the vanes are slanted a little so it won't be as effective. I made a cooling fan once for an alternator out of some heavy aluminium plate - all I had was a drill and some tin-snips.
Julian. |
Posted: Tue Apr 03, 2012 4:32 pm Post subject: |
Turn the fan around on the shaft? _________________ Mike - MVPeters at comcast.net
