Austin Princess Van den Plas Limousine DM 4 1962
British heritage cars
PostPosted: Sat Apr 21, 2012 4:36 pm    Post subject: Austin Princess Van den Plas Limousine DM 4 1962 Reply with quote
Hallo Folks
I have a problem with the gearbox from the Austin Princess limousine.
If the engine does'nt turn I can go in all the gears, but if I drive I can't get further than second gear...
Anyone sugestions?
Kind regards,
Jonathan
PostPosted: Sun Apr 22, 2012 4:05 pm    Post subject: Reply with quote
Jonathan,
It sounds like the clutch isn't disengaging properly. With the engine running is it easy to select 1st gear, IE no crunching? While holding the clutch pedal down does it creep forward? Is the clutch hydraulic or mechanical?
Art
Churchill Johnson
PostPosted: Sun Apr 22, 2012 9:42 pm    Post subject: Reply with quote
You say you cannot get further than second gear, will the lever come out of second but not engage third or fourth,also can you engage all gear's with the engine running but car not moving, if so have you tried engaging third gear and gently slip clutch to get moving then change into fourth if it will not do this i would think gearbox, as it should be possible to to engage second,third,and fourth gear without using the clutch, it may be a synchro going faulty,try these thing's first then come back on here with the result's.
PostPosted: Tue Apr 24, 2012 5:37 am    Post subject: Reply with quote
Thanks Wink It's not my car and it's not in my back garden Crying or Very sad My friend owns it so I'll give him your tips, and will tell you what happend!
Thansk Allot!
kind regards,
Jonathan
